Window Crank
Old Jul 2, 2003 | 09:37 AM
30yr Wait's Avatar
30yr Wait
Default Window Crank
The **** on the window crank came off. Is it possible to re attach it?
Pat
Old Jul 2, 2003 | 09:40 AM
NHvette's Avatar
NHvette
Default Re: Window Crank (30yr Wait)
You mean the handle ? Is the splined shaft still sticking out ? There is a spring
clip that goes in the back side of the handle (available at all parts stores).
You put the clip in the slots - and push it onto the splined shaft.
EDIT - you mean the rotating **** on the end. I think it's a peened-over
rivet that hold that on. You'll have to get a door handle clip tool to get the
crank off. Then, you might be able to peen the rivet back over - but it won't
last for too long (my guess). You might want to get a new or used one.
EDIT2 - Um - I think I might have an early style handle for ya - IM or email me.
:seeya
[Modified by NHvette, 9:43 AM 7/2/2003]
[Modified by NHvette, 9:44 AM 7/2/2003]
Old Jul 2, 2003 | 09:52 AM
Graemeinvette's Avatar
Graemeinvette
Default Re: Window Crank (NHvette)
I had the rotating **** come off, I was able to put it back by removing the arem with the clip tool and screwed it back on with a self tapping screw in the remains of the peened over rivet. I then took the self tap out again applied plenty of locktite and a plain washer, screwed it back in and its been fine for about a year now. Of course having said that I will get into the car this weekend, wind the window down and....
:D :D :smash: :smash:
Old Jul 2, 2003 | 12:38 PM
30yr Wait's Avatar
30yr Wait
Thanks guys....I'll try that tip with the screw, if it doesn't last, I'll just get a new one.
Thanks Again
Pat
To Window Crank
