DD2K
Old Jul 2, 2003 | 12:37 PM
SCVetteGuy's Avatar
SCVetteGuy
Default DD2K
Just got Desktop Dyno and I could use some help. I don't know everything about my engine. Its the stock 1980 L-48. I was also wondering if its possible to put in stock manifolds, with different mufflers. Thanks for your help.
Old Jul 2, 2003 | 12:42 PM
bence13_33's Avatar
bence13_33
Default Re: DD2K (SCVetteGuy)
For an intake you would use the "dual plane" feature. For the exhaust you would use "stock manifolds and mufflers". Your cam specs are:
Intake Lift: .390"
Exhaust Lift: .410"
Intake Duration @ .050": 195
Exhaust Duration @ .050": 202
Lobe Seperation: 112 Degrees
Old Jul 2, 2003 | 12:48 PM
SCVetteGuy's Avatar
SCVetteGuy
Default Re: DD2K (bence13_33)
Thanks bence, but how do I put in lobe separation?
I could also use some help with the Cylinder Heads and Valves.
[Modified by SCVetteGuy, 12:14 PM 7/2/2003]
Old Jul 2, 2003 | 09:54 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Where did you get the Dyno?? I'd like to try it!! :cool:
Old Jul 3, 2003 | 10:38 AM
SCVetteGuy's Avatar
SCVetteGuy
Default Re: DD2K (DP77Vette)
I bought it from Summit. Nice fast delivery!!!!
I think I did my engine wrong though, b/c with my few, very few mods, it says 223 Hp, and 286 ft-lbs. And I'd say the Hp is a little higher than it should be.
[Modified by SCVetteGuy, 10:04 AM 7/3/2003]
To DD2K
