Replacing a A.C. compressor seal?
Old Jul 2, 2003 | 01:18 PM
pletner's Avatar
pletner
Default Replacing a A.C. compressor seal?
Hi everybody! I need to replace the seal in my a.c. compressor. Do I have to vent the charge to do this? It would be great if I could do this with everything still hooked up. Thanks, Paul :seeya
Old Jul 2, 2003 | 01:24 PM
Missileman's Avatar
Missileman
Default Re: Replacing a A.C. compressor seal? (pletner)
If you are replacing the metal or ceramic seal behind the clutch assembly, you do not have to evacuate your system.
Replace it with the ceramic seal reguardless of what you have in there now. The special seal puller tool should be available for loan/rent at a larger auto parts store.
Old Jul 2, 2003 | 01:48 PM
mrvette's Avatar
mrvette
Default Re: Replacing a A.C. compressor seal? (Missileman)
Yeh, man,....you DO have to evacuate the system....that's what the seal is about...holding in the freon and oil....
GENE
Old Jul 3, 2003 | 08:10 AM
pletner's Avatar
pletner
Default Re: Replacing a A.C. compressor seal? (mrvette)
This is the ceramic seal behind the clutch. So this is what holds the freon and oil charge in? Thanks, Paul
To Replacing a A.C. compressor seal?
