350 V. 383
Old Jul 2, 2003 | 03:39 PM
shamby's Avatar
shamby
Default 350 V. 383
I have my 350 engine out of the car and plan on adding the Edelbrock Performer RPM Kit to it. I was wondering since the engine is out of the car, how much more performance would I get out of a 383? Is it worth the extra bucks and work? Any input??
Old Jul 2, 2003 | 03:41 PM
Ganey's Avatar
Ganey
Default Re: 350 V. 383 (shamby)
Yes, will run like a BB.
:cool:
Old Jul 2, 2003 | 04:03 PM
gkull's Avatar
gkull
Default Re: 350 V. 383 (Ganey)
I will never build another 350 ci motor. just get the kit which is internally balanced so you can use your damper and flex plate.
I've actually decided that i won't even build 383's anymore. It's 396 ci or better.
Old Jul 2, 2003 | 04:29 PM
OatBoy's Avatar
OatBoy
Default Re: 350 V. 383 (gkull)
extra cubes are always nice
Old Jul 2, 2003 | 05:09 PM
Boofers's Avatar
Boofers
Not that I know from personal experience but as the old saying goes -
There is no replacement for displacement
Old Jul 2, 2003 | 07:39 PM
Clink69's Avatar
Clink69
YES,
You will be glad you did.... :yesnod:
Old Jul 2, 2003 | 07:49 PM
garagedweller2's Avatar
garagedweller2
Default Re: 350 V. 383 (Clink69)
Do you sacrifice revibility?
Old Jul 2, 2003 | 08:22 PM
Corey_68's Avatar
Corey_68
Default Re: 350 V. 383 (garagedweller2)
No, 383's were built as "Cheater" motors in the world of dirt track cars and these engines live at 8Krpms. To the eye they look like a 350 but have more torque. These racers balance the crank so you could use a 350 balancer, thus what fooled everyone. Nowdays many just run the larger 400 balancer and be done with it.
A 383 will gain about 30lbs of torque more than a equally built 350 and gain about 25hp in the process. The cheapest kit I've found is here for less than $500 --> http://www.speedomotive.com/Budget%20383.htm
[Modified by Corey 68, 8:24 PM 7/2/2003]
Old Jul 2, 2003 | 08:36 PM
Clink69's Avatar
Clink69
Use 6" rods to take care of that....
Old Jul 2, 2003 | 09:33 PM
shamby's Avatar
shamby
Thanks for all the info.
What about this kit? http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
I am kinda suprised the 25HP is all that you might gaine from a 383
Old Jul 3, 2003 | 03:12 PM
Weird Science's Avatar
Weird Science
Well, if you think about it you only have 9% more cubes. Also, don't take that number as gold. It is very configuration dependent. A 383 will allow a bigger cam w/o sacraficing driveability. Another benefiit of a 383 is the longer stroke allows for more leverage of the piston pushing down on the crank.
Old Jul 3, 2003 | 04:07 PM
Fevre's Avatar
Fevre
Default Re: 350 V. 383 (Weird Science)
Plus the torque curve is broader, just what you want in a street machine. :thumbs:
Old Jul 3, 2003 | 04:45 PM
shamby's Avatar
shamby
Default Re: 350 V. 383 (Fevre)
What kinda pistons should I run. I have Edelbrock 64CC heads and the airgap intake. Still trying to decide on the carb, cam and pistons.
Agian thanks for all the info.. :thumbs:
[Modified by shamby, 4:46 PM 7/3/2003]
To 350 V. 383
