Fuel pump leaking
Old Jul 2, 2003 | 09:37 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Fuel pump leaking
I swear, if it's not one thing, it's another. While setting my idle I was checking for any leaks and sure enough, my mechanical fuel pump is leaking. It is a Holley mechanical fuel pump I bought about 3.5 yrs ago. I believe it's just the basic one, looks like this:
Well, I traced it down to the lower diaphragm thingy. I tried tightening the bottom bolt that holds it together but it's still leaking....pretty badly actually. It wasn't leaking before and this just suddenly started.
So what does this mean? Is the pump bad, or is there a fix for it? This is horrible timing cause I took off tomorrow so that I can take it in to have the exhaust work finished. :mad
Old Jul 2, 2003 | 09:45 PM
isosceles's Avatar
isosceles
Default Re: Fuel pump leaking (tshort)
I JUST started a thread on stuff happening like this the other day. Don't you hate it when you have the parts to do a mod, then something breaks and you have to fix it? And I'm talking about something you can't improve with a mod like a headlight switch! :banghead:
My stock fuel pump leaked the same way and I just had to replace it. I don't know if your Holley one has a replaceable diaphragm.
I feel you pain.
Old Jul 2, 2003 | 09:54 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Bummer Travis....
I had that same pump bolted to my new engine and dumped it on E-bay as Mark said I did not need it with the 355 he sold me. There's no return line and I would have had to run a fuel regulator. The problems with running a stock fuel pump to a 3/8" fuel line on a 750 carb? Finding a fitting that adapts from the fuel pump to that line.
How is the new engine running?
Old Jul 2, 2003 | 10:10 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Fuel pump leaking (bgrice)
Well, it WAS running fine. It was actually idling quite nicely until I noticed the fuel leaking. Although, it does have a hesitation when I blip the throttle but I wasn't going to try to address that until the exhaust work was done. Now once again I have something else to fix/replace. :cry
Any other suggestions????
Old Jul 2, 2003 | 10:37 PM
LFZ's Avatar
LFZ
my pump did the exact same thing..i tried tightening the bolts, and it didn't help.....i took it off and installed the stock pump back on.
Old Jul 2, 2003 | 10:50 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Fuel pump leaking (REDSHARKONBOYDS)
You know, I think I still have the old one. I might try that. Ugh, I hate installing fuel pumps, it's so crowded right there and getting that little rod held up is a biotch. Not to mention spilling gas all over the place. I guess it's worth a try though.
Old Jul 2, 2003 | 10:55 PM
WhyFly's Avatar
WhyFly
Not a 100 percent sure but I think Holley has replacement parts for most of their pumps. It's most likely the rubber diaphram you can see around the outer edge of the pump. You may want to check their website for more info. If the pump is only 3 years old..they may do it on warranty...Well....Maybe..
:D :steering:
Old Jul 2, 2003 | 11:03 PM
WhyFly's Avatar
WhyFly
That pump pushrod can be a challenge when you're trying to reinstall a pump.
A shop teacher showed me a trick years ago to minimize the frustration. Smear the rod with a little bearing grease and stuff it up in it's hole. It won't hurt a thing and will keep the rod up while you're trying to reinstall the pump..
Oh yea....really really tiny hands are a big help as well... :D :U
Old Jul 2, 2003 | 11:10 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Default Re: Fuel pump leaking (WhyFly)
....figures, Holley tech. staff is off until next Monday. :cuss :mad
Why can't things just work like they're supposed to?
I found the old pump and that won't work unless I feel like cutting off my AN fitting so it will slip over the barb fitting. I think I'll just take off that whole bottom section and take a look at it tomorrow morning. Maybe I will see something or be able to seal it better.
Old Jul 3, 2003 | 12:11 AM
Crash Dummy
We all know what you are going through Travis. I just covered up my vette as I was tired of being dissappointed. It is amazing though that just staying away from it and all the frustration can bring on the *lightbulb* to fix those problems we run into. If you can't get the holley fuel pump to work I will give you a work around for the weekend. Autozone sells a 3/8" braided fuel line kit that works with barbed outlets. It's not high tech, but you just size it to length. I am guessing that is what you have to your carb outlet. There's no reason to screw up your AN fitting set-up. And O-Reilly's carries a fitting that will adapt from the stock fuel pump(90 degree) to 3/8" barb. They may have to get it from their warehouse, but that's less than 4 hours in most cases.
I love long weekends.... 4 days off.
To Fuel pump leaking
