Hooker Side tubes: Any install tricks??
Old Jul 6, 2003 | 06:11 PM
Corey_68's Avatar
Corey_68
Default Hooker Side tubes: Any install tricks??
I have the Chrome Hooker Side mounts and ready to install the side tubes. Any tips on getting the tube on without scratching up all the chrome? I thought about flairing the opening of the tube but afraid I may cause the chrome to crack and flake.
Any advice?? :confused:
Old Jul 6, 2003 | 06:21 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: Hooker Side tubes: Any install tricks?? (Corey 68)
Check for any sharp edges around the tube ends and remove with a fine rat tail file. Coat the inside of the tubes with an anti sieze compond....the header collectors will scratch from installing the sidetubes nothing you can do to prevent it.....
Old Jul 6, 2003 | 07:25 PM
WA 2 FST's Avatar
WA 2 FST
yellow 72 is correct. Nothing you can do to prevent the inside collector from getting some scratches, but who cares, really? You want a tight seal there, for sure.
I just used a bit of WD-40 and mine went on without too much hassle. The anti-seize is probably better, although I've had mine off twice and didn't have a big issue with removal.
Old Jul 7, 2003 | 08:16 AM
Corey_68's Avatar
Corey_68
Default Re: Hooker Side tubes: Any install tricks?? (WA 2 FST)
I know I will scrath them up, just didn't want to flake off any chrome.
Thanks for the tip guys. :cheers:
To Hooker Side tubes: Any install tricks??
