Spark plug wire routing
Old Jul 7, 2003 | 01:34 AM
rexx78's Avatar
rexx78
Default Spark plug wire routing
I put the engine in, but I didn't put the spark plug wires underneath the engine mounts and inside the shielding. Now they won't fit.
I think I have to lift the engine a little, but I don't have the engine hoist anymore... Can I lift it with a jack, or should I find another way to route the #1-4 wires?
Old Jul 7, 2003 | 06:42 AM
jerryp58's Avatar
jerryp58
Default Re: Spark plug wire routing (rexx78)
Do you have stock mounts?
The wires should go through the stock mounts.
Old Jul 7, 2003 | 07:09 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Those wires should go through the engine mounts without any problem, but you will need to remove the boot first. Gently remove the boot to avoid damage to the wire, then a little silicone spray will help with re-assembly. I am pretty sure I routed mine between the mounts and the block, there is just enough room there.
[Modified by Big Fish, 6:10 AM 7/7/2003]
Old Jul 7, 2003 | 10:30 AM
rexx78's Avatar
rexx78
Default Re: Spark plug wire routing (Big Fish)
I forgot to mention. I have Energy Suspension poly motor mounts. I will try to take the boots off to route them.
Thanks. :cheers:
To Spark plug wire routing
