5-port washer fluid pump
BTW 2 post for the windsheild wipers and 2 for headlights, what is the 5th for? inlet? :confused:
As Tom and Ed have already noted, the five port pump was standard equipment on 1970 and early 1971 Corvettes as standard equipment. The headlight washer system was phased out during 1971, but the various parts were discontinued at different times. One of the interesting effects of this procedure is that the five port pumps were used for a period of time after the system was no longer functional (the headlight washer nozzels were the first thing to go). As such, the factory used a "jumper" hose between two of the ports and used the other two for the wiper arm connections.
1969 Corvettes also used a headlight washer system, but the pump used a seperate solenoid operated transfer for the headlights; the main pump remained the three port type.
Chris,
As far as your question, two outlets are for the wiper arms, two outlets are for the headlights, and the last is an inlet which draws fluid from the washer reservoir.
The "T" fittings that you suggested using will most likely not work... At least it generally doesn't during PVs that I have witnessed at NCRS events. The factory used a one way check valve which prevented fluid from flowing backwards as the pump cycled. 1969 Corvettes used one of these valves very close to pump itself while 1970-1971 Corvettes used two valves, one at each headlamp.
These check valves were used in other GM vehicles with headlight washers so you may be able to find a couple by hitting the salvage yards... I don't believe any vendor is currently reproducing these.
I doubt that a five port rebuild kit was ever available (if it was, it has been discontinued long ago), but if you already have a five port pump, you can use a couple of three port rebuild kits to rebuild it. There was an article in the NCRS Restorer magazine that detailed the process... I'm would imagine that copies are available.
Regards,
Not original, but it would be easy for someone to restore to original if they wanted. Now the big question is, does that make me Bubba?
Hans
I kept the stock washer bottle and used a separate pump removed from an aftermarket system, plumbed in near the bottle and wired just like Wrencher's.
Works fine :D
Wrencher... Bubba?? Nah. You just re-engineered it. NCRS ?? Nah. You flunk. :)
Tom
True enough for 1968-1972 cars (and probably continuing on for a few years after that). The bag style reservoir was used when the Corvette in question was equipped from the factory with air conditioning... Cars without air conditioning mounted the plastic bottle style reservoir on the right (passenger) side inner fender. Because this space was occupied by the compressor, hoses, POA valve, etc. when air conditioning was installed, the location was changed to under the left (driver) side fender, close to the firewall... And of course because this space was confined, a flexible bag was used in place of the rigid bottle.
For what it's worth there are two styles of bags used on the 1968-1972 cars, one with a long neck and one with a short neck. There is apparently no reason why one or the other would be required in production and their use overlaps... It is quite possible that they were provided by two different suppliers which would explain the variation.
Regards,
My last question, could I use a pump from someone else that uses headlight washers, like a Mercedes? I realize that the hose sizes would be metric and I'd have to clamp them, and the connector would be different, but its just where power is sent to open and close the valves, right?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2423133581
Jim
