You shouldn't need a spacer for the TTII's. You can check out the American Racing website for a dealer in your area http://www.americanracing.com/dealer...sp?section=dlr.
My wheels are closeto the TTII, they are Eagle Alloy 211, 17"x8". Cost me less than TTII's.
I know it's not a shark but w/ everything being equal I didn't need spacers the AR TTII's 17x7 with 4" bs probably could have gone to 8" wide in the rear if I moved the PB bracket... I used 225/50/17 but I'm sure you can go wider on a shark...With no modifications to boot...Dave..
Anything bigger than that...you either have to have spacers or go with a offset on the wheels...which you really shouldn't do if you are planning on racing ,etc etc etc.
As far as rim width goes, 68-82 all have an 11" wheel well. So you can go to a 10" wide rim. If you do go w/a 10" wide rim you have to relocate your PB bracket or fo to offset t-arms.
Dan-
I would love to put 17" wheels on my car but the problem is...I love white raised letters on the tires. :( I've neve been able to find anyone that makes them that I like. I didn't think the sidewalls were that small that they couldn't do it if the wanted to. I'm pretty much stuck with the 15" wheels if I want WRL's :cry
Jay those wheels look sharp cant wait to see the car done I am going to paint my vette 2003 yellow soon and want to put those wheels on at the same time what do you guys and girls think of the color? :cool:
What is the ascept ratio on those 17"'ers? Do you still have the same turning radius (rubbing of the front tire)? They look great, really fill the wheel well nice.
From: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
Re: 17 inch Wheels (78 Vette)
The car in my sig has Crager S/S rims and they do need spacers. TTII's are a wheel similar in look and popularity, but they do not need spacers.
The difference is in the design of the wheel. The TTII has spokes that come out from the center to the edge of the rim so that it clears the brake calipers. The Crager S/S spokes, on the other hand, are flat and unable to clear the caliper without the use of a spacer. I think this holds true for any size of these rims with regard to Corvette fitment. :cheers:
