C3, how does it ride compared to a C4??
Old Jul 27, 2003 | 04:24 AM
Light84vette's Avatar
Light84vette
Default C3, how does it ride compared to a C4??
I have never ridden in one before, but how does it ride? Are the stock spring rates too hard or too soft? DOes it roll into the corners too much? :confused: I really like the looks of a C3 and I'm pretty sure not that many of them go into auto-x, more likely the drag strip.
Plus does it have the cockpit feel like a C4, or does it have the openess feel like a muscle car? What would you C3 Owners say your car does best besides looking good?:D Handling, acceleration? What about the BIg Blocks? :confused:
Old Jul 27, 2003 | 05:08 AM
Pete Z's Avatar
Pete Z
Default Re: C3, how does it ride compared to a C4?? (Light84vette)
It highly depends on the year....the later years are imho the better drivers,where the early years are the more sensational ones in performance.
I drive the 82 as a daily driver,and it feels more comfortable to me then the early C4's.
Doesn't have the performance,but never let me down in the last 16 months either.
I personally wouldn't trade the sexy looks of the C3 for the better handling of the C4..... :cheers:
Old Jul 27, 2003 | 05:43 AM
Larry B.'s Avatar
Larry B.
Default Re: C3, how does it ride compared to a C4?? (Pete Z)
Early C4's rode pretty harsh. By the early 90's they were much improved. 92's up have a much nicer interior. Bose strereo is great. AC works great. 28-30 mpg on the highway. 17 in town. The car handles excellent. Excellent brakes.... Here's what I found that I didn't like. C4's are much harder to get into due to the high sill. With the roof panel off C4's feel like rubber, ..as a matter of fact the first time I drove the 92 I had without the roof panel in , I thought something was wrong with the front end . Also.. Parts are very expensive. I replaced ONE shock and the motor that controlled it, $400. Everything is controlled through the computer. Learn about it or pay big bucks getting work done. I trader a real nice 92 for my 69 3 years ago.. Would I trade back.?.. NOT a chance.
[Modified by bluevetteman, 5:45 AM 7/27/2003]
Old Jul 27, 2003 | 06:31 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: C3, how does it ride compared to a C4?? (bluevetteman)
(Blue; I think he has a C4)
The early C3's have Solid body mounts and ride pretty stiff.
They corner pretty flat out of the box but can be made better.
They are even more cave like than the C4 IMHO
Old Jul 27, 2003 | 09:49 AM
Larry B.'s Avatar
Larry B.
I guess I mis-read the question. C3's are not nearly are comfortable on longer trips, noise level is higher, they don't handle as well as C4's but you will get a lot more attention in a C-3.
Old Jul 27, 2003 | 09:54 AM
PRNDL's Avatar
PRNDL
As mentioned above, it varies HUGELY by year (and engine). My 68 bigblock rides pretty much like a buckboard with wooden wheels..... I feel bumps in the pavement that don't exist and I watch the car in front of me very carefully --- if it dips sharply than I better slow down or I might bottom out (ouch!!!). I seem to be able to go around corners better than my volvo wagon, but I wouldnt want to push it. I think the late 70s sharks ride much nicer (I bet they actually feel like a car) and probably corner better too. :) MJ
Old Jul 27, 2003 | 10:30 AM
Rick68's Avatar
Rick68
Default Re: (MNJack)
:iagree: It doesn't take much to bottom out my 68 and I find after a long drive I'm exhausted. My 73 drives nicer and doesn't bottom out near as easy, it corners better and I don't feel as drained after a long cruise.But I enjoy driving the 68 with the top down the most it just has that classic car feel so its more than worth the little discomforts :cheers:
Old Jul 27, 2003 | 10:52 AM
zwede's Avatar
zwede
Default Re: (73Stingraycoupe)
I have a 71 BB and GF has a 96 LT4. When I bought the 71 it was not a joy on the bad roads here in Dallas. Previous owner installed a glass spring and the thing bounced like crazy. Over the years I have slowly improved ride & handling. Edelbrock IAS shocks, late C3 steel spring. Bigger swaybars. 73-up rubber body mounts. 17" rims and high perf Z-rated tires. Now it handles REAL well. Ride is tremendously improved. The 96 is still better on really bad roads, but the 71 is not too far back. As it sits now it is enjoyable even on bad roads. After the IAS shocks I don't bottom out nearly as much.
A late C3 will ride better than an early C4, though.
Old Jul 27, 2003 | 01:41 PM
Marc80's Avatar
Marc80
Well, when you ride in it the whole package (you, the car, life) looks better with the C3 :D
Old Jul 27, 2003 | 02:27 PM
fauxrs's Avatar
fauxrs
Default Re: C3, how does it ride compared to a C4?? (Marc80)
I concur. My 78 rides tons better than my 84 (with the optional kidney belt suspension) did. There isnt a lot fo roll in the corners but a stock C3 is no match for the C4 in stock form. Modified the C3 will ride as well as the mid/late 80's C4 and handle similarly.
I have taken my 78 on several long trips and thie biggest difference is cockpit heat and noise which are high in the C3 and low in the C4 otherwise it can be a comfortable ride.
As a general rule of thumb the newer C3's starting in 77 or 78 were more civilized ride wise, culminating in the 82 which was a very comfortable riding car.
Old Jul 28, 2003 | 02:16 AM
Light84vette
Default Re: C3, how does it ride compared to a C4?? (fauxrs)
I like the Chrome Bumbers better then the Fiberglass ones. So that Pre 1974 right? :confused: ALso could one take out the carpet and install some padding or the heat sheild material of some kind to stop the excess heat and noise? :confused:
Old Jul 28, 2003 | 07:55 AM
fauxrs's Avatar
fauxrs
73 had chrome on the rear only. Yes heat shield can be installed with varying levels of success. you can also wrap the exhaust which is the biggest culprit for heat, and you can install the tunnel filler - around the bellhousing - which keeps the tunnel from becoming a source for hot air.
Old Jul 28, 2003 | 10:22 AM
Glutamine83's Avatar
Glutamine83
as much as I love my C3, i don't have airconditioning,
not only do my kidneys hurt, but i get heatstroke most of the time as well
it's not a comfortable car
To C3, how does it ride compared to a C4??
