rear shock mount question
Old Jul 28, 2003 | 11:15 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default rear shock mount question
I am putting on new rear shock lower mounts, the ones that go through the lower part of the rear spindle. The new mounts have a ring of serration that appears to be there to bite into the spindle mount. I do not have the old mounts to compare.
My question is this: does the shoulder of the new mount have to be against the part of the spindle it goes through? It seems that a lot of force would be necessary to draw the mount through the spindle the entire way. I will post a pic later.
Old Jul 28, 2003 | 11:19 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: rear shock mount question (7t2vette)
Yes, that's how they make sure the lower shock mount stay's in. Get your half inch breaker bar and impact socket ready...... Or a nice 1000foot pound Impact.
Old Jul 28, 2003 | 11:21 AM
Bobchad's Avatar
Bobchad
Mine were drawn in using a standard 1/2 inch rachet and socket.
Old Jul 28, 2003 | 11:23 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: rear shock mount question (Bobchad)
Wow, I thought I was gonna get a double hernia trying to get mine on. lol
Old Jul 28, 2003 | 11:39 AM
Bobchad's Avatar
Bobchad
Default Re: rear shock mount question (88'Cubka)
I reused the old ones. Perhaps they had less metal on them from having been put in and taken out.
Old Jul 28, 2003 | 11:51 AM
norvalwilhelm's Avatar
norvalwilhelm
I thought my mounts had a "D" in them and there was a left and right side?
Old Jul 28, 2003 | 12:15 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Yes, most likely. I had to cut mine out.
Norv, they do but that just keep's them from rolling in the spindle. and most of the time they don't fit 100% tight in the original spindle (Just my experience working on 3 or 4 differnt vette rear ends).
David
:cheers:
[Modified by 88'Cubka, 9:15 AM 7/28/2003]
Old Jul 28, 2003 | 12:48 PM
7t2vette's Avatar
7t2vette
Okay, thanks guys, I will tighten them all the way on. I casually tried tightening them yesterday with a regular 3/8 rachet, and it seemed that I was using an excessive amount of force, but I will try again with the breaker bar tonight.
Norval, there is a flat spot on the threaded section of the shock mount, but I am talking about the same part of the mount that doesn't have any threads on it.
Old Jul 28, 2003 | 06:26 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
There is a right and left version, both may require a fair amount of torque to seat, but factory specs call for 80 foot pounds on them anyway, should be more then adequate to seat them fully.
Old Jul 28, 2003 | 10:33 PM
Blue68's Avatar
Blue68
St. Jude Donor '08
My new ones were really difficult to install also. What I ended up doing was to crank on the nut with a 1/2" drive rachet while hitting the other side of the shock mount with a hammer. Hitting it with a hammer made it easier to pull the shock mount all the way to the shoulder in the spindle. Something to think about.
wayne h.
Old Jul 28, 2003 | 11:07 PM
Shark Racer's Avatar
Shark Racer
I took the old ones off when I did the rear strut rod deal. I do not recall it being a big deal. Took the shock off, loosened the castle nut and hit it with one of those pieces of metal that's got a round end on one side and a flat side on the other side, banged on that with a hammer. (Horrible, horrible grammar...)
Came out easy. When I reinstalled it, I used an impact gun to pull it through.
-Steve
Old Jul 29, 2003 | 12:43 AM
The Dude's Avatar
The Dude
Default Re: rear shock mount question (norvalwilhelm)
:withstupid:
Mine, too--there was a flat side milled on the part that goes through the hole. (How's that for technical lingo, huh?) Must be some kind of variation among different years?
Old Jul 29, 2003 | 10:51 AM
Stewart's74's Avatar
Stewart's74
Default Re: rear shock mount question (Pacin'California)
-Steve
REmember, this comes from a guy in Cali. My Vette came from Canada. I had to cut the old shock mounts off :eek:
To rear shock mount question
