Underbody care
Old Jul 29, 2003 | 10:07 PM
JAMES69's Avatar
JAMES69
Default Underbody care
I just bought a 1969 convertible (350hp), Lemans blue with blue interior. Frame on restored in late 80's. I noticed some surface rust on frame. I'd like to put something on it to further protect it. Ideally I could just brush something on without hurting the valus of the car. Any suggestions?
Old Jul 30, 2003 | 10:59 AM
ROD NOCK's Avatar
ROD NOCK
Default Re: Underbody care (JAMES69)
Welcome to the forum!
If you can get down to bare metal, then prime and paint. If not, try to remove as much loose rust as possible. Then use one of the 'rust converter' products such as POR-15, Carroless or something similar. It's best to top coat these products with a paint for protection.
Try these links: http://www.eastwoodco.com/ (look under 'rust protection') & http://www.por15.com/
Old Jul 31, 2003 | 09:27 PM
JAMES69's Avatar
JAMES69
Default Re: Underbody care (ROD NOCK)
Rod,
Thanks for the advice. I'll check out the web site and give it a try.
Jim
To Underbody care
