engine to frame ground cable
Old Jul 31, 2003 | 07:58 PM
stickboy's Avatar
stickboy
Default engine to frame ground cable
The cable that goes from the engine to the frame on my vette is badly corroded. what is it called? and where is a good place to buy a new one? :cheers:
Old Jul 31, 2003 | 08:12 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Re: engine to frame ground cable (stickboy)
I would think you could build your own ground without much trouble. It's not much more than insulated battery cable and connectors that can be crimped on. Bring yours to let's say a NAPA and tell them that it is the ground that goes from the engine block to the frame. Odds are they will even build it for you. It never hurts to make sure you tell them it is a C-3 vette. I brought a valve cover off the '71 into NAPA last Saturday to get a PCV valve and a fitting and when I walked in one of the guys said.... "Ahhhh... a big block!". Had no troubles at all as they went out of their way. :cheers:
Old Jul 31, 2003 | 09:37 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
It's called a ground cable. These people have them: http://www.lectriclimited.com/
Old Aug 1, 2003 | 06:36 AM
UKPaul's Avatar
UKPaul
Hi Stickboy,
Where on the engine is your cable bolted?
:cheers:
Old Aug 1, 2003 | 08:35 AM
flynhi's Avatar
flynhi
Since the frame is used as a ground wire in Vettes, these connections are more important than most people think. If you have yours made locally, be sure to match the wire size or go one size larger and use high quality crimp on connectors. Use copper wire and connectors - not aluminum.
Then be sure to scrape/clean the point of connection on the frame and block down to the bare metal. Install with new bolts and lock washers and cover with anti corrosive gel.
Follow this procedure also on the cable that connects the battery to the frame.
Then clean up the positive cable connection on the starter and on both battery terminals. You may be surprised at the difference in starter operation, brightness of headlights and wiper operation.
Old Aug 1, 2003 | 09:41 AM
Stewart's74's Avatar
Stewart's74
Default Re: engine to frame ground cable (flynhi)
:iagree:
Especially check where the Neg BAtt cable attaches to the frame :yesnod:
Old Aug 1, 2003 | 02:11 PM
stickboy's Avatar
stickboy
Default Re: engine to frame ground cable (UKPaul)
Paul, this cable botls to the block where the starter support bolts, then it bolts to the frame near the engine mount.
flynhi and Stewart's74, I plan to replace the battery cables at the same time, I figure they're just as old
Old Aug 4, 2003 | 05:54 AM
UKPaul's Avatar
UKPaul
Thanks. With Headers fitted, that bolt is very difficult to get to :rolleyes:
:cheers:
To engine to frame ground cable
