Brake calipers
Old Aug 2, 2003 | 01:45 PM
arrio76's Avatar
arrio76
Default Brake calipers
I blead the brakes on my 76 today and noticed that the front an rear calipers were different. The rears had 3 bleaders each and the fronts had just one each is this correct?
I used the one man bottle and tube system to blead all 4 corners. Worked great! Nice firm brakes now. :D
Old Aug 2, 2003 | 02:54 PM
redvetracr's Avatar
redvetracr
Default Re: Brake calipers (arrio76)
arrio,
One in the front is correct and the two facing forward in the rear are correct, the "third bleeder" pointing to the back should be a plug BUT just leave the bleeder in as a plug (NO need to try to bleed the third one).
...redvetracr
Old Aug 2, 2003 | 04:53 PM
arrio76's Avatar
arrio76
Default Re: Brake calipers (redvetracr)
Thanks, I wasn't sure if someone had swapped out a different model year caliper some time in the past. I did bleed all three fitting though.
The brakes are much better. They don't pull to the right any more. They still feel a bit spongy and I still get about a quarter pedal travel at the top before they grab. I may replace the flex lines next.
To Brake calipers
