Has anyone had problems installing Brute Force U-joints?
Old Aug 3, 2003 | 11:07 AM
70BBvert's Avatar
70BBvert
Default Has anyone had problems installing Brute Force U-joints?
In the process of replacing the u-joints in the half shafts. Everything is cleaned up & preped for re-assembly. Installed the ujoint in the spindle flange but I cant get the locking clips in. Installed one side & forceed the joint against the clip but there is not tenough room to get the second clip installed.
Brute force part # 2-0053BF
Old Aug 3, 2003 | 11:37 AM
Larry B.'s Avatar
Larry B.
Default Re: Has anyone had problems installing Brute Force U-joints? (70BBvert)
It sound like you have a needle trapped under the cap on one side.. Look at the grease seal near the cross. If one side isn't seated tne the problem is in that bearing.
Old Aug 3, 2003 | 01:37 PM
79VetteMike's Avatar
79VetteMike
Default Re: Has anyone had problems installing Brute Force U-joints? (bluevetteman)
I agree. I rebuilt my suspension and had the same problem with Spicer u-joints. People suggested that I had a dropped needle bearing, but I thought that couldn't be possible, because I am so particular about everything. I just knew I couldn't have let that happen. Anyway, it happened. I damaged the plastic bearing guards in the process. Anyway, I fixed the problem and it all went back together. U-joints can be a huge pain in the butt if you haven't done them before. Once you learn a few tricks, it gets easier. Make sure that the area where the u-joint cups go is clean and smooth. I was afraid that I might take too much material away while i was cleaning them; however, making them shiney with emory cloth is almost essential. Make sure there are no burrs and you should be ok.
Old Aug 3, 2003 | 01:39 PM
79VetteMike
Default Re: Has anyone had problems installing Brute Force U-joints? (79VetteMike)
A guy showed me a really great way to install them. If it isn't the needle bearing, you can call me and I can walk you through it on the phone. Good luck..
Old Aug 3, 2003 | 02:45 PM
70BBvert's Avatar
70BBvert
Thanks Guys,
I had cleaned, bead blasted, & painted everthing already and installed the u-joint in the spindle flange first. Took them apart a couple of times to make sure I had'nt dropped a needle. After playing for a while I decided to try the half shaft end. Went together in two minutes.
Then I figured it out. The spindle flange had bent slightly durring dis-assembly. So I bolted it onto the spindle using a .005" shim to flex the flange
the other way & was able to tap the joint in the rest of the way. Everything moves nice & smooth.
Jim
Old Aug 4, 2003 | 02:54 PM
70BBvert's Avatar
70BBvert
By the way, here's what they look like now. Forgot to take before pics, don't really like the light gray/silver. Might take them out & repaint them.
To Has anyone had problems installing Brute Force U-joints?
