Loose smart struts
Old Aug 5, 2003 | 10:38 AM
Wrencher's Avatar
Wrencher
Default Loose smart struts
After reading earlier posts about the lock nuts on the VB&P smart struts loosening up after a period of use, I have kept an eye on mine since I installed them a few months ago. Sure enough, both outside nuts came loose, even though I had tightened them to what I felt was plenty.
Sooo, has anyone solved this? I will obviously put a wrench to them often, as I much prefer the handling. Locktite is an option, but would that prevent adjustment in the future or maybe damage the threads if loosened? Lets hear it...
Hans
Old Aug 5, 2003 | 11:18 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Loose smart struts (Wrencher)
Locktite Blue would be best in that case. The red is for parts you never want to pull apart again - ever.
Blue is a bit more forgiving and is a good thread locker.
Now I am off to climb under my car and check my struts... :leaving:
Old Aug 5, 2003 | 11:36 AM
gkull's Avatar
gkull
I've never had a problem!:) The last time I had to screw with them was when I came over for the Laguna historic race last fall to see you guys and I tore up the U-joint and half shaft.
That was an easy job. I unbolted the U-joints and the four wheel spindle bolts. then loosened the smart strut lock nuts and rotated the shaft 8 full turns. then lifted the half shaft out. Pressed the new U-Joints into the new shaft and reinstalled. Rotated it back 8 full turns and locked it down. So my camber was the same as before.
Then I was out having fun again.
Before I would locktight it, just put a bead of silicone then the nut couldn't rotate.
Old Aug 5, 2003 | 11:43 AM
UKPaul's Avatar
UKPaul
Default Re: Loose smart struts (BSeery)
Yup, I've used the blue stuf (Threadlocking) repeatedly on threads with no problems caused by it. For particularly bad loosening problems on bolts that need very infrequent attention I've had no problems using the red Stud 'n' Bearing fit (don't used the retaining compounds!!!! You'll never get it apart again).
I've never had a close look at the Smart Struts. Is there any way you can put an extra nut on to lock the locknut?
How much difference did the Smart Struts make? Are they worth the time & money to replace stock struts (with good bushes) with?
:cheers:
Old Aug 5, 2003 | 02:53 PM
Wrencher's Avatar
Wrencher
Default Re: Loose smart struts (UKPaul)
Paul, I'm extremely happy with them, not withstanding the loosening nuts. I especially like two features. First, the eccentrics allow me to position the struts level respective to the halfshaft, reducing bump steer to a minimum. Second, it's very easy to dial in any degree of camber you like. I'm running one half degree negative at the moment. Cheers.
Hans
Old Aug 5, 2003 | 11:34 PM
bigvette1's Avatar
bigvette1
QUOTE
Yes there is a way to install an extra nut to snug up on the other.
Alignment wise you have more control and setting of the rear camber than the stock with the eccentric. Strength I think is the same. If the bushings are the poly type they will outlast the bushings on the stock one.
Use Locktite Blue on all rear suspension parts. It keeps the nuts in place.
Old Aug 6, 2003 | 07:17 AM
UKPaul's Avatar
UKPaul
Default Re: Loose smart struts (bigvette1)
Thanks for the replies :thumbs: I can feel a Florida vacation with a few empty bags coming up :D
:cheers:
Old Aug 6, 2003 | 11:28 AM
ROD NOCK's Avatar
ROD NOCK
Blue Loc-Tite will allow 'service' to the fastener/threads w/out probs. Can be reapplied again and again. I also like the 'silicone bead' idea! :cool:
Old Aug 6, 2003 | 11:47 AM
73jst4fun's Avatar
73jst4fun
I had the same problem when I installed the smart struts. You can ad another locking nut or use the blue Locktite which I did. The locktite did the trick and the struts have not come out of alignment since. I also carry the tiny tube of Locktite (Pep Boys) in the emergency kit. The struts are still easy to adjust if needed even with the Locktite applied.... :thumbs:
Old Aug 6, 2003 | 05:21 PM
Wrencher's Avatar
Wrencher
Default Re: Loose smart struts (73jst4fun)
Blue Locktite it is...
Thanks guys.
Hans
Old Aug 6, 2003 | 05:41 PM
NHvette's Avatar
NHvette
I don't have the smart struts - but do have the VBP adjustable strut rods -
circa 1999. After initial install, I tightened them and sure enough - as warned
by a friend - the nuts loosened up. I tightened them down more than enough -
and since then they have stayed put. Perhaps a little aging and corrosion and
dirt helped to keep them in place. Maybe it was me hanging from the wrench.
:seeya
To Loose smart struts
