Special timing cover for Roller Cam???
Old Aug 5, 2003 | 09:08 PM
marky mark's Avatar
marky mark
Default Special timing cover for Roller Cam???
On a retro fit roller cam do you need a sturdier timing chain cover to handle the cam button movement?
Do these units still fit behind the water pump o.k. ???
Thanks, Mark :flag :chevy
Old Aug 5, 2003 | 10:17 PM
69vette66's Avatar
69vette66
Default Re: Special timing cover for Roller Cam??? (marky mark)
I am using a sturdier timing chain cover. But I also had the problem with the short water pump hitting the cover. GM has the low profile bolts that will cure this problem, or take a grinder and grind the head down until it clears the timing cover.
:cheers: Larry
Old Aug 5, 2003 | 10:22 PM
zwede's Avatar
zwede
I'm using the stock steel cover and it has been fine for about 4 years now. I wouldn't recommend the thin gauge china/taiwan chrome covers, though.
Old Aug 5, 2003 | 10:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have the Cloyes two piece aluminum, nice piece, kinda pricey but you spent alot on the roller cam. It has two small discs inside, less friction than the cam button.
Very sturdy so there is not much flex, (the cam button on the last cam almost wore through the cover and it was badly distorted.)
Fits perfect behind short water pump :D
[Modified by MotorHead, 9:24 PM 8/5/2003]
Old Aug 5, 2003 | 11:22 PM
marky mark's Avatar
marky mark
Default Re: Special timing cover for Roller Cam??? (MotorHead)
That's a nice looking motor!!!
Regards, Mark
To Special timing cover for Roller Cam???
