Poll---does you power steering leak
Old Aug 8, 2003 | 06:43 AM
Dalannex's Avatar
Dalannex
Default Re: Poll---does you power steering leak (Jvette73)
I couldn't vote because I have 2 that don't leak, one that does, and one with no power steering. The 75' that does leak shouldn't now. I rebuilt the control valve yesterday and it is sitting on the bench waiting to be installed. I rebuilt the valve and cylinder in the 81', no leaks, the 80' is original and doesn't leak.
-Justin
Old Aug 8, 2003 | 08:23 AM
Ganey's Avatar
Ganey
Ever heard of the trick of adding a little brake fluid to stop the leaks. I was told it swells the seals a bit and can stop leaks. I dont know if its a good idea or not. Could it hurt anything?
Do this instead:
Get No Leak made by Gold Eagle 14 fl. oz.- it works- most of the stop leak products do not work.
Old Aug 8, 2003 | 08:35 AM
Alwyn678's Avatar
Alwyn678
Default Re: Poll---does you power steering leak (Cookwithvette)
It used to till I got the stop leak....No leaks in two years
Old Aug 8, 2003 | 11:24 AM
BB wowbagger's Avatar
BB wowbagger
Default Re: Poll---does you power steering leak (Alwyn678)
When i bought the car,the system was filled with ATF fluid and it dripped from the ram and controlvalve.I drained the system and refilled with GMs Servo fluid and the leaks stopped..ATF may be the cheaper way,but its the wrong way if you ask me :cheers: :thumbs:
Old Aug 8, 2003 | 12:23 PM
adamdinat's Avatar
adamdinat
Was leaking a quart every 2 weeks. Needed to be filled every other time I took it out. Replaced the control valve last night. We will see how long it stays tight.
Old Aug 8, 2003 | 12:35 PM
mean8t's Avatar
mean8t
Finally Fixed it about a year ago. I could pour fluid in and watch it come out the front shaft. I thought it was the shaft seal until I pulled out the pulley and shaft by hand.
Old Aug 8, 2003 | 12:59 PM
Corey_68's Avatar
Corey_68
Default Re: Poll---does you power steering leak (mean8t)
Nope, not after replacing the seals. :thumbs:
Old Aug 8, 2003 | 01:33 PM
Boofers's Avatar
Boofers
Its fairly common for those old PS pumps to leak. Mine did, tried PS stop leak, no work. Replaced PS pump with rebuilt one and figured while I was at it would do the 4 hoses as well. Now its perfect. Prolly cost me around $150CDN for the whole shebang. I pride myself on telling people my car doesn't leak anything :D
Old Aug 8, 2003 | 05:07 PM
Rockn-Roll's Avatar
Rockn-Roll
Mine leaked when I first got it. I actually bought a control arm and was trying to figure out how to remove the pitman arm before I gave up. I did tighten all the connections though, and that stopped it from leaking. I also added some power steering fluid that has a stop-leak additive. So, I don't know what did it...tightening the connections or adding the stop-leak.
Old Aug 8, 2003 | 08:15 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: Poll---does you power steering leak (bgrice)
I foresee this to be the first poll in the C-3 section that is a complete landslide. There is a sure fire remedy though. Only drive straight. :D
:lolg: :lolg: :lolg: That was good...!!!
Old Aug 9, 2003 | 07:28 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Re: Poll---does you power steering leak (AGVI)
I think the results are a bit Florida Bush-Gore'd as I see alot of hanging chads that really probably would have been *yes* if the question was clarified a bit. Even my power steering doesn't leak now as I changed out all of the lines, but it did when I got it. So, I voted *yes*.
Old Aug 9, 2003 | 10:09 PM
Raydon 3000's Avatar
Raydon 3000
Used to, tightened up fittings on the lines now it doesn't.
Old Aug 10, 2003 | 06:43 AM
  #33
Larry B.'s Avatar
Larry B.
Mine leaks a little on occasions. I don't know where. Sometimes it will be weeks with NO drips at all and then the next time I come out there is a 3 inch puddle under the control valve. I can operate the steering for a few cycles and find nothing. I think it's possesed..... I had another corvette that only leaked from the pump reservior "0" ring when it sat for a few days.
Old Aug 10, 2003 | 07:17 AM
  #34
Jvette73's Avatar
Jvette73
We still got more than 1/2 of them leaking according to the poll. That would have been my guess at to what the results would be. But yur right though. Theres probably a few no votes that should be in the yes catagory.
Old Aug 10, 2003 | 08:56 AM
  #35
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I have no power steering ...
Old Aug 11, 2003 | 08:20 AM
  #36
pzcg7l's Avatar
pzcg7l
C3 of Year Finalist (stock) 2019
2018 C3 of Year Finalist
Default Re: Poll---does you power steering leak (GrandSportC3)
:withstupid:
Old Aug 11, 2003 | 09:21 AM
  #37
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Not a drop, for now anyway. :D
To Poll---does you power steering leak
Old Aug 11, 2003 | 02:51 PM
  #38
chevyjeff's Avatar
chevyjeff
Default Re: Poll---does you power steering leak (Avette4me)
After replacing all lines and multiple control valves I found that over greasing the fitting on the control valve will burst the seals and create a leak. If you dont do your own chassis lube and take it an oil chang service make sure they dont grease it. I have not gresed mine in two years and have no leaks and steering is good as it gets.
Old Aug 11, 2003 | 06:21 PM
  #39
NHvette's Avatar
NHvette
Default Re: Poll---does you power steering leak (chevyjeff)
I bought the 75 with new control valve and lines installed.
It still leaked slightly - so I bought the rebuild kit for the ram.
It still leaked after that. Maybe when I get it back together, I'll
try some of that stop leak.
:seeya
Old Aug 11, 2003 | 06:22 PM
  #40
wayne_69_427's Avatar
wayne_69_427
No but everythingis new hose's, cylinder , pump and control valve
