1980 spark plug wires
Old Aug 14, 2003 | 09:19 AM
Jmccreary's Avatar
Jmccreary
Default 1980 spark plug wires
For the past 8 days I have been working on the '80. There was an exhaust leak at the exhaust manifolds so I decided to take the thing down to the block and clean it up while I am at it. I am wanting to keep everything stock. So last night I decided to install the spark plug wires. What a chore that was. The PO had installed aftermarket wires running along the top of the motor and in the process had removed motor mount bolts without replacing to get the old wire out of the lower heat shield. Took three hours to get everything right. What a nightmare job it was. I plan to have everything back together by Friday night.
Old Aug 14, 2003 | 09:44 AM
bloodvette80's Avatar
bloodvette80
Default Re: 1980 spark plug wires (Jmccreary)
i put new wires on my 80 about 2 months ago.... it took about 20 minutes... made a big difference though, since i had a few burnt ones from the headers. Hope you have good results too. :cheers:
