Steering Shaft Play Question
Old Aug 14, 2003 | 12:10 PM
Paul L's Avatar
Paul L
Default Steering Shaft Play Question
(This question relates to my 1967.) Where the steering shaft meets the rag joint coupler I have about 1/2" of in/out play. There is a bolt there that looks very much like it has a torx head. Should I tighten down on that? If yes what socket fits that head? (Torx did not exist in 1967.)
[Modified by paul67, 12:56 PM 8/14/2003]
Old Aug 14, 2003 | 12:47 PM
sray454's Avatar
sray454
Default Re: Steering Shaft Play Question (paul67)
It certainly should be tight, and a standard 12 point socket should work just fine...
Old Aug 14, 2003 | 03:20 PM
Paul L's Avatar
Paul L
Default Re: Steering Shaft Play Question (sray454)
I snugged the shaft up with a 7/16" 12-point socket. Thanks for your help!
To Steering Shaft Play Question
