HELP!!! Stripped caliper bolt!?!
Old Aug 15, 2003 | 02:55 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default HELP!!! Stripped caliper bolt!?!
How can I remove a stripped caliper bolt?
Not the two holding the caliper halves together, but the two that mount the caliper to the bracket?
PLEASE HELP!!! THANK YOU!!! :confused: :confused: :confused:
Old Aug 15, 2003 | 03:09 PM
BB68Vett's Avatar
BB68Vett
Default Re: HELP!!! Stripped caliper bolt!?! (AGVI)
I don't understand the question. Is the bolt stuck in the bracket and it won't come out. If that is the case I would remove the caliper completely from the bracket and use a c-clamp to apply pressure to the bolt as you turn it with a wrench.
Old Aug 15, 2003 | 03:36 PM
NHvette's Avatar
NHvette
Grind the head off and turn the stud out with a pair of vicegrips or a stud removal tool.
Old Aug 15, 2003 | 03:41 PM
AGVI's Avatar
AGVI
Default Re: HELP!!! Stripped caliper bolt!?! (BB68Vett)
That IS the problem, I cant remove the caliper from the bracket :confused:
Old Aug 15, 2003 | 03:45 PM
Twin_Turbo's Avatar
Twin_Turbo
front or rear? If it's the rear you are kind of screwed, you'll have to take apart the hub assembly to remove the caliper and bracket as one.
If it's the front, it's pretty easy. Remove the bolts holding the 2 halves together and take off the outer 1/2. Remove the bolt that go through the steering knuckle and the large nut on the anchor plate (have to remove the hub but that's just removing the dust cap, remove castle nut and pull it off w/ bearings) then just pull the rotor and the hub.
Marck
[Modified by Twin_Turbo, 2:46 PM 8/15/2003]
Old Aug 15, 2003 | 03:50 PM
Brettmc's Avatar
Brettmc
Is the head or the threads stripped?
Brett :thumbs:
Old Aug 15, 2003 | 04:08 PM
AGVI's Avatar
AGVI
Default Re: HELP!!! Stripped caliper bolt!?! (Brettmc)
Brett :thumbs:
head...
Old Aug 15, 2003 | 04:11 PM
AGVI's Avatar
AGVI
Default Re: HELP!!! Stripped caliper bolt!?! (Twin_Turbo)
Fronts...ok, is it possible to remove the brake pads if I split the caliper in half? If so, I can just replace the pads and rotor and not worry about the bolt....or am I dreaming? Much appreciated Marck!!!
[Modified by AGVI, 4:12 PM 8/15/2003]
Old Aug 15, 2003 | 04:17 PM
Twin_Turbo's Avatar
Twin_Turbo
yeah, it's possible to replace the pads if you remove the slider pin. However, i would just take the whole del apart and replace it NOW. Why wait for a later time and have to do it all again.
Old Aug 15, 2003 | 04:32 PM
Jvette73's Avatar
Jvette73
Yeah youll probably have to deal with it sooner or later. but if all you want to do is replace the pads then all you need to do is remove the pin and slide em up and out. the problem is when you do this the springs in the caliper bores will likely push the pistons out making it difficult to slide the new pads in. The vette parts suppliers sell these clips made especially to simplify this process. You slide the clips down inbetween the pad and piston and they hold the pistins back while you slide the new pads in. Iv heard some people say they just pryed the pistons back with a screwdriver and slid the pads in.
Old Aug 15, 2003 | 04:58 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: HELP!!! Stripped caliper bolt!?! (Jvette73)
Prying with a screwdriver will most likely fowl the pistons in the bores and will almost certainly lead to leaks
Old Aug 15, 2003 | 05:16 PM
Jvette73's Avatar
Jvette73
The clips are the easy way to go. Now I know that the Haynes manual isnt considered by everyone to be the best but thier instructions say to pry the pistons back in the bore with two large screwdrivers. If yur not carefull I can see how the pistons could get cocked out of alignment and possibly jam so you do make a good point anyway. The key is to remove the master cap so the fluid can flow up there without restriction of the sealed system. its a good idea to scoop some fluid out first so the resivior doesnt overflow in the process.
Old Aug 15, 2003 | 06:14 PM
OldSchool's Avatar
OldSchool
Get yourself to Sears and get the "Bolt Out" kit.. Spiral Fluted bolt remover for stripped heads.. The more you turn it to get the bolt head off, the deeper it bites into the head.. Get the air tool BO kit, it'll be off in 2 minutes.. :smash: :smash:
Old Aug 15, 2003 | 07:30 PM
Brettmc's Avatar
Brettmc
Default Re: HELP!!! Stripped caliper bolt!?! (OldSchool)
:iagree: Uh huh.
Brett :thumbs:
Old Aug 15, 2003 | 08:25 PM
Mike Smith's Avatar
Mike Smith
Just removed a front caliper with rounded bolt head with the Sears tools - took about 30 seconds - best $20 I ever spent.
Old Aug 16, 2003 | 11:16 AM
AGVI's Avatar
AGVI
Default Re: HELP!!! Stripped caliper bolt!?! (Mike Smith)
thanks for the advice guys...
To HELP!!! Stripped caliper bolt!?!
