brake booster question
Old Aug 20, 2003 | 09:33 AM
junkjp's Avatar
junkjp
Default brake booster question
The parts books show the same booster 68-76 and a different one for 77-82 does anyone know what the difference is between the two?
Old Aug 20, 2003 | 10:21 AM
markdtn's Avatar
markdtn
Default Re: brake booster question (junkjp)
I believe 68-76 is painted black and has an adjustable rod between the booster and master cylinder. 77-82 is Cad. plated and the rod is not adjustable.
Old Aug 20, 2003 | 11:53 AM
junkjp's Avatar
junkjp
Default Re: brake booster question (markdtn)
A little black paint and a master cyl. matched to the booster should be okay.
Thanks alot
Old Aug 20, 2003 | 02:59 PM
gerry72's Avatar
gerry72
The year difference is due to a change in master cylinder design. The early booster was for a power brake master cylinder that used a deep piston pushrod well (same depth as the manual brake cylinder but with the larger 1.125 diameter piston bore). They changed the master cylinder piston design in 77 for a shallow piston pushrod well. You can use either booster as long as you use the correct master cylinder.
To brake booster question
