lower shock mnt????
Old Aug 30, 2003 | 12:32 PM
petty44's Avatar
petty44
Default lower shock mnt????
has anyone had trouble installing lower shock mounts, :( my left rear came out no problems, used the tool and out it came, while installing I was 1/16th of an inch from seating and the threads pulled through the nut :sad: I was using a box end wrench and then a 3/8 impack.. now I have to wait untill tuesday to get another from CCentral, It says made in usa I will use a 1/2 inch impack wrench next time....bushog :skep:
Old Aug 30, 2003 | 10:54 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default Re: lower shock mnt???? (petty44)
I had the same problem with some I bought that were made in China. The supplier bought them back and paid for shipping as well. The torque on those nuts should be 85 ft/lbs, I would not recommend using anything other than a torque wrench. Give them a little rap with a hammer once they get close, it might help to reduce the pressure of drawing them on with the nut.
Old Aug 31, 2003 | 08:53 PM
GTR1999's Avatar
GTR1999
Be sure that you don't have any rust or paint on them to hang them up. I like to wire brush them and use some never-seize on them. I tap them in then tighten the bolt. You can get new ones or reconditioned ones form Bairs. I used a reconditioned one and you can't tell the difference between new.
Gary
Old Sep 7, 2003 | 09:24 PM
petty44's Avatar
petty44
well I got a used one from the junk yard it looks almost new!!!! :thumbs: I installed it on sat. no problems with this one, torqued to 75lbs and stainless steel cotter key :smash: I think the one I got from C/central was to big in diameter.. also only paid $25.oo for itr :thumbs: :thumbs: bushog
To lower shock mnt????
