My Harmonic Balancer Fell Off - Help!
I decided to drive the Vette to work today. As I was pulling into the parking lot, my power steering went out and I heard a thumping sound - I figured the serpentine belt had broken. I parked the car and popped the hood - the belt had come loose, but was OK. I started looking at the pulleys and all of them were in line except for the harmonic balancer - it was jutting out about 1/4". I figured the bolt had slipped or something and I'd just fix it after work.
Well, after work I had planned on tightening up the bolt or just banging the balancer back into place with a hammer. However, when I put my hand on the balancer it just fell off.
Here are pics of it and the bolt:
http://langhoff.dhs.org/balancer.jpg
http://langhoff.dhs.org/strippedbolt.jpg
As you can tell, the bolt was stripped pretty badly. The bigger concern, however, is the inside of the balancer - it's rounded out completely. It slips right on and off the crank without any resistance. The crank itself has some scrapes on it from where the notched edge of the balancer rubbed against it.
Any ideas on what could have caused this? Do you think I could get away with just using another balancer and helicoiling the crank bolt hole? Or does the crank probably need replacing?
Thanks for any input.
[Modified by Langadorf, 8:08 PM 9/5/2003]
if the new one is loose, get a few beads of weld and file it to fit. will take a few hours but it sure beats changing the crank.
could not see the pics, so i assume u will figure out something for the bolt.
[Modified by Matt Gruber, 8:29 AM 9/6/2003]
What sort of damage to the crank snout surface is "acceptable"? There are some scrapes on it, but if a new balancer fits tight, is it OK to run with?
