full roller rocker tick
Old Sep 15, 2003 | 11:00 AM
madvette74's Avatar
madvette74
Default full roller rocker tick
should you hear these tick with the valve covers on? i would of thought that these would be quiet, there not loud, but it's noticible when the hoods open, if this is normal, why do they tick??
Old Sep 15, 2003 | 11:11 AM
Fevre's Avatar
Fevre
Default Re: full roller rocker tick (madvette74)
3 things to look at
1. Exhaust leak, gives a ticking noice.
2. Loose rocker stud.
3. Rocker hitting the valve cover, get a thicker gasket or double up your gaskests.
Old Sep 16, 2003 | 07:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: full roller rocker tick (Fevre)
Mine make quite a clatter with a solid cam however you would think they would be quieter with a hydraulic cam, did you adjust them with the motor running ?
Another thing is that there is a little play, not musch but it's there in the roller tip itself maybe that's what you are hearing.
Which Crane rollers are they and are the new ?
Old Sep 16, 2003 | 08:16 PM
Stratos's Avatar
Stratos
I'm using the Comp roller tip rockers with a hydraulic cam in my 72 350, no noise at all with stock alumimun LT1 valve covers and stock heads.
Old Sep 16, 2003 | 09:03 PM
Jvette73's Avatar
Jvette73
If its a hydraulic cam they should be quiet no matter what rocker arms are being used. If the noise is actually comming from the valve train, somethin aint right.
Old Sep 16, 2003 | 09:21 PM
no_radio's Avatar
no_radio
There's a little noise, especially if you are running one of Comp's Xtreme Energy cams. I called them about my 454 with a 256XE cam. they said that with the steep ramps of the XE cams there is more valvetrain noise.
My 350 with Comp 256H and 1.6 full roller rockers makes a different sound at idle than it did with stock rockers, but it's not really a tick. It's more muffled and mechanical, like a sewing machine. If you have a loud ticking noise, or if it's not the same for every cylinder then you may have a problem.
Jeff
Old Sep 16, 2003 | 09:28 PM
CF6873's Avatar
CF6873
Default Re: full roller rocker tick (no_radio)
I had a set of Harland Sharp full rollers that came with my 73 project car so I put them on when I rebuilt the engine. I installed a 262XE cam and I had a noticeable clatter from the rockers even after adjusting them with the engine running. I then put on the stock rockers and have no noise. I sold the rollers and I am going to live with the stock ones for a while anyway. Craig
Old Sep 17, 2003 | 10:59 AM
madvette74's Avatar
madvette74
thanks,
i believe your right, i checked both sides everything is till the exact way as when they where first set, they are crane blazer rollers, and i am using a xe 274 comp cam, it does sound like a sewing machine..lol. very slighty,
To full roller rocker tick
