Electric fan angle?
Old Sep 17, 2003 | 11:43 PM
Chris69's Avatar
Chris69
Default Electric fan angle?
I've read through some of the archives, but didn't find much discussion on the downward angle of radiator mounted electric fans. Question is, how much heat are you building under the hood when idling? You know...right around the carburetor for those of us that don't have snorkles and ducts. Seems like the electrics blow the air down and out, and the mechanical fans will circulate air all around the compartment. :confused:
Old Sep 18, 2003 | 08:28 AM
Frankenvette's Avatar
Frankenvette
Default Re: Electric fan angle? (Chris81)
I made the switch from mechnical to a single 16" electric. My electric fan is mounted at the same angle as the radiator, so I guess the angle of the fan blows air at a slight downward angle. Not sure this really causes any cooling under the hood...its hot under there regardless.
Old Sep 20, 2003 | 12:00 AM
Chris69's Avatar
Chris69
Default Re: Electric fan angle? (Frankenvette)
Yeah, it does seem to stay pretty warm under there. Just want to make sure it doesn't get any worse with electrics at that angle.
Anyone else have some thoughts/experience between the two?
:chevy
Old Sep 20, 2003 | 01:18 AM
Enad's Avatar
Enad
I'm on of those "snorkel" guys so I can't comment on the engine intake. I did notice the passenger compartment stays cooler. It may be that the air is going out the bottom rather than over the engine and to the firewall.
Dane
[Modified by Enad, 6:10 PM 9/20/2003]
Old Sep 20, 2003 | 08:03 PM
bigvette1's Avatar
bigvette1
Default Re: Electric fan angle? (Enad)
Cane's comment on the passenger compartment being cooler is a real +++ for electrics. Glad someone made notice.
Old Sep 20, 2003 | 08:35 PM
flynhi's Avatar
flynhi
You will gain 1% HP for every 10 degrees that you drop intake air temp.
Find a way to snorkle.
To Electric fan angle?
