mechanical tachometer to electric tachometer?
Old Sep 19, 2003 | 08:49 AM
rparkervette's Avatar
rparkervette
Default mechanical tachometer to electric tachometer?
I have a 68 with a distributer driven tach. I noticed in new years GM went to a eletric tachometer. Has anyone changed out theirs? Im thinking of changing to fuel injection (holley cmdr 950) and is requires a HEI distributer, which means I will loose my funtional tachometer unless I convert to electic. Thanks
Old Sep 19, 2003 | 09:02 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: mechanical tachometer to electric tachometer? (rparkervette)
I've done this switch on all my early C3's... It's easy... If you want to keep the stock look, buy a used '75 - '77 tach (electronic). It installs in the same location.. The wiring is easy.. You just need 3 wires hooked up.. One to ground, one to ignition + and one to the tach port of either the tach port on your HEI or MSD box (if you have one)...
[Modified by GrandSportC3, 9:03 AM 9/19/2003]
Old Sep 19, 2003 | 09:04 AM
zwede's Avatar
zwede
68-71 used green numerals, 72-up switched to white. I got the 75-77 electric tach for my 71 and switched the faceplates. That gave me the correct color mumerals with the higher 71 redline and electric movement.
Old Sep 19, 2003 | 11:36 AM
Missileman's Avatar
Missileman
There are a couple companies that sell HEI's with a tach drive. Kind of pricey. Would be cheaper to change the face with an electronic one.
Old Sep 19, 2003 | 10:17 PM
lyonsh's Avatar
lyonsh
Clocks by Roger can convert your mechanical tach to electric, and it will retain its original appearance. We just had our 72's converted. Roger does GOOD work! :cheers:
To mechanical tachometer to electric tachometer?
