Nightmare projects
Old Sep 22, 2003 | 11:13 AM
RLaFarge's Avatar
RLaFarge
St. Jude Contributor
Default Nightmare projects
Have you ever started out on a simple quickie project and it turn into a total nightmare? Mine was this simple little turnsignal switch change.
Anybody care to storys about their nightmare projects?? :grouphug:
Old Sep 22, 2003 | 11:32 AM
Shark Attack's Avatar
Shark Attack
Default Re: Nightmare projects (RLaFarge)
I started on a simple IRS swap into my mustang, then got the need for 430 gears (which were my nightmare) Took the IRS apart, installed the gears, put back together and had a whine upon deceleration. I knew it was shimmed right and had fluid. Took it back apart a month later only to find metal shavings in the housing and the ring gears had pulled away from the carrier housing by 1 thread on 6 bolts. So I had to rebuild it again and put it back with the 355's it came with. Cobra IRS is a PITA! I hope the vette wont be too bad when I get it.
JB
Old Sep 22, 2003 | 11:40 AM
GDaina's Avatar
GDaina
Yup....initial project was to replace the rear crossover brake line due to severe rust and scaling...ended up doing a frame off resto... :rolleyes:
Old Sep 22, 2003 | 12:14 PM
ROD NOCK's Avatar
ROD NOCK
Alot of us are in this boat!
I started out to do rear bearings, check the trailing arms and brakes. Ended up doing a complete rear susp/drivetrain rebuild. :smash:
Didn't turn into a total nitemare as much as it turned into a time & $$ sucker!
Old Sep 22, 2003 | 02:12 PM
tabbruzz's Avatar
tabbruzz
Two nightmares:
1) installing SLP headers on my 99
2) rear wheel bearing on my 79.
Old Sep 22, 2003 | 02:19 PM
Alwyn678's Avatar
Alwyn678
Default Re: Nightmare projects (tabbruzz)
Heater core on my 74 vert w/AC
Old Sep 22, 2003 | 02:21 PM
75Rag's Avatar
75Rag
Default Re: Nightmare projects (Alwyn678)
I started out to fix my tach, ended up gutting the interior, nothing left attached except the steering wheel.
Old Sep 22, 2003 | 04:52 PM
petty44's Avatar
petty44
see my post about half shafts and bubba at work!!!!!... :crazy: bushog
Old Sep 22, 2003 | 04:57 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Nightmare projects (75Rag)
:withstupid:
Old Sep 22, 2003 | 06:07 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Hey, you wanna take peek into my garage? :smash: Started out to replace the passenger side power window switch. :crazy: You can bet I'll hire someone to fix my window next time! :lolg:
Old Sep 22, 2003 | 07:28 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
yeah, I bought a Vette....need I say more? :confused:
:D :D :D :D :D :D
Old Sep 22, 2003 | 10:20 PM
75Rag's Avatar
75Rag
Default Re: Nightmare projects (BSeery)
I started out to fix my tach, ended up gutting the interior, nothing left attached except the steering wheel. :withstupid:
yah ... but at least you've got a nice red stapler to put stuff back together :lolg:
Old Sep 22, 2003 | 10:42 PM
joeveto's Avatar
joeveto
Cruise-In V Veteran
A lot of mine are like that. But the most preposterous was when I went to polish the alternator before a meet. The wire popped off the alternator, grounded itself out, and took both fusible links with it. I wasn't too familiar with the car, not like now. So it took me two days to diagnose and another week to fix. Sad.
Then there was the fuel filter change that resulted in a seven month, multi thousand dollar engine and front end rebuild. That was a hoot.
:hurray:
Old Sep 22, 2003 | 11:08 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
:nopity Seems like every part I remove/repair/replace I have three more to fix. But then again I try to make the fix with the best parts I can find and mods that I’ve always wanted to make.
What kills me is doing the repair loop. :rant:
1)shark repair needs a bolt, adhesive, part or tool.
2)drive to Home Depot, True Value, Checker, Pep Boys, Harbor Freight or Chevrolet.
3) browse the catalogs and order from Zip, Ecklers, Mid America, Craftsman, Summit, Jegs or GM parts direct.
4)drive to UPS, Home Depot, True Value, Checker, Pep Boys, Harbor Freight or Chevrolet to return parts/tools for whatever.
Guess I should celebrate when something goes right the first try.
:jester
Old Sep 23, 2003 | 08:39 AM
Brettmc's Avatar
Brettmc
I ordered a front p-brake cable shortly after I bought mine. The PO said it would need it for the p-brake to operate properly. Well, that turned into a replacement of the entire p-brake system and 2 new rear calipers. Car was down for like 2 months.
Brett :thumbs:
Old Sep 23, 2003 | 04:26 PM
Fast81's Avatar
Fast81
The first was buying and towing my 81 out of the guys backyard. :eek:
The second was taking it in cuz the TH350 was slipping in 2nd. That led to a TCI 700R4, new driveshaft/half shafts, and a 3.54 rearend with total poly-bushing replacement. :D
Old Sep 23, 2003 | 07:41 PM
79MakoL82's Avatar
79MakoL82
Mine started out as one broken rear spring mounting pad bolt. Turned into an entire rear end re-build. As I took one thing apart to get to something else, I'd discover a whole NEW problem. :rolleyes:
Of couse, some of it went like this..."AW SHUCKS AND JIMMINY CRICKETS HONEY! LOOK WHAT I HAVE TO REPLACE NOW!!!!!!!" :D
The good news is...I have a completely re-built rear end now!! :D :cheers:
Old Sep 23, 2003 | 07:58 PM
73Gator's Avatar
73Gator
Default Re: Nightmare projects (79MakoL82)
I started out pulling the engine to rebuild it. Ended up pulling the body off.
Old Sep 24, 2003 | 03:12 AM
DREGSZ's Avatar
DREGSZ
I don't even want to get started...
To Nightmare projects
