2700 Clams!
With that in mind, I decided to take it to a Corvette specialty shop to get it checked out, mostly to fix the leaking T-Tops, but have everything else checked too. It is about to become my daily driver, since my Pathfinder's lease is up next week.
So, the "Fix the T-Top Leaks" visit to the shop has suddenly turned in to a $2700 visit.... here's what they found:
Turn Signal Switch arm is bent, needs replacement
Door Lock electrical connectors and wire need replacement
Rear Body Mounts are rotted
Lower Control Arm Bushings are gone
Parking Brake Cable broken
Rear Strut Rod Bushings need replacement
Rear Leaf Spring hanger bushing need replacement
3 Brake hoses are cracked and rotting
Two sets of T-Tops reseal, adjust and adjust windows.
Speedo Head bad
So to get all of that fixed, minus the speedo head and body mounts is about $2700. UGH!! :banghead:
But I still love the car, right? :crazy:
Speedo Head bad
snuff, but later learned that rust had taken it's toll to a greater extent than I
had imagined. I can see a future post - after bringing her in to replace the #4
body mounts - and the shop now discovers that the birdcage is rusted out
and only the #1 mounts are hanging on.
I woudl suggest using the forum knowledge and doing most of these repairs
yourself. Perhaps leaving the control arm bushings and body mounts to a
trustworthy shop. You should be able to tackle most of that list over a few
months during the winter. Good luck - and remember: That $2700 is less than
a years worth of new car payments.
:seeya
I saw the list and I can relate to changing control arm bushings. I had to replace the upper and lower control arm bushings on my 78 to get it to pass inspection. My dad and I undertook the project and that was a real headache. Basically we ended up disassembling the entire front end to get the things out of there :eek: , and then we drilled out the old rubber bushings to get them out of the control arms. I can tell you, that was a real pain and I'm sure you will pay top dollar for someone else to do it.
Just my $0.02
Tom
- Not sure about 79, but on earlier models it just screws in.
- Do you really need power door locks? This can be put off without any problem.
- Can do yourself in a couple of hours. Did the one on my convertible (which has the deck lid supports/springs mounted on top of the rear mounts) in one day. On a coupe you do not have the hassle of the deck lid mounting system.
- Get a second opinion from an alignment shop. If bad then need to be replaced.
- Easy self fix
- See Lower Control Arm above
- Bolt in operations, easy dyi
- double check condition. If bad replace.
- main purpose of going to the shop
Speedo Head bad
- What is bad, does it not work?
tom....
[Modified by Tom73, 11:55 AM 9/25/2003]
If your turn signals still work, don't worry about it
You can fix
You can fix
You can fix
You can fix
Maybe your T-Tops just need new weather-stripping.
Speedo Head bad
To summarize, grab a 12 pack and invite a buddy over to "drink some beer" this weekend
:reddevil
And yeah, the amount of work to replace the lower control arm bushings is crazy! It's like 3 or 4 hours labor. Definately something I could not do myself!
Go get yourself a decent cheap S10 pickup or some 4 popper sedan and keep the vette for your fun toy. Especially with winter coming up.
If you start to have trouble with the vette and its your DD, you might develope a love/hate relationship that sours the experience.
My .02
Brent...
