454 question ?
Old Sep 25, 2003 | 03:08 PM
2TS-73's Avatar
2TS-73
Default 454 question ?
i am going to look at a 76 three quarter ton pickup with a 454 in it . will this be a tall deck motor , i know the heads will be the peanut style heads, but everthing else should fit in my 73. never know when i might need a backup motor in case mine gives out .
Old Sep 25, 2003 | 03:20 PM
79Corvette02's Avatar
79Corvette02
Default Re: 454 question ? (2TS-73)
If you get a tall deck motor, won't you end up having problems with headers and all the regular acessories having interference? :confused:
Old Sep 25, 2003 | 05:38 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Get the block serial numbers then go check Here There are only a few Bowtie 454's listed as TALL.
Old Sep 25, 2003 | 10:22 PM
rrent's Avatar
rrent
I do not believe it will be a tall block in a 3/4 ton truck --- most were used in bigger 1 ton+ trucks.
Old Sep 25, 2003 | 10:31 PM
no_radio's Avatar
no_radio
Default Re: 454 question ? (rrent)
:iagree:
The tall deck is a dump truck/HD engine. If it's in a pickup or Suburban it's standard deck and all your accessories will fit.
Jeff
Old Sep 26, 2003 | 09:34 AM
C3 - 81's Avatar
C3 - 81
Try this address and it will point u in the right direction i hope. http://www.diabolicalperformance.com/c3bigblock.html
To 454 question ?
