Plug wire routing
Old Sep 30, 2003 | 09:59 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Plug wire routing
Installing headers - What's the best way to route the plug wires?? Across the valve covers or underneath like original?? I kinda prefer underneath but, not sure how to go about doing it.
Any suggestions and/or pics are appreciated!!
By the way it's a 77 with Dynomax!
Thanks!
:cheers:
Old Sep 30, 2003 | 10:16 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Plug wire routing (DP77Vette)
underneath, much better looking.
Moroso etc. make special routing looms for under header routing. It's a PIA but possible
Old Sep 30, 2003 | 10:24 PM
1972 Shark's Avatar
1972 Shark
I have Hookers on my 72. My wires are routed underneath in the original locks. As long as you get the correct wire set this should'nt be a problem just time consuming. I will be doing a replacement of wires with Pertronix Flame Thrower wires this week (they look stock but the specs on them are great) and plan to route them the same way. Good luck, I'll let you know how my install goes.
:smash:
WOOD
72 350, TH 400, Edelbrock Performer Intake, Hookers, 2.5" exhaust w/Flowmasters, Pertronix Electronic ignition, Pertronix Wires will be installed tomorrow w/Rapid Fire Plugs , Heat Barrier Kit just purchased install in the next couple weeks. K&N (ordered)
Old Sep 30, 2003 | 10:27 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
After burning through three sets of plug wires, I bought the Made For You looms. They're expensive, but worth it. But I still burned a few boots. So now I'm going for the boot protectors.
Cheers.
Old Sep 30, 2003 | 11:09 PM
NHvette's Avatar
NHvette
Default Re: Plug wire routing (joeveto)
Just make sure you don't get any small oil leaks.
When I pulled the wires out of the bottom looms on my 75,
the 7mm wires were bloated to almost double that. Holy crappoli.
I'll be keeping mine over the top.
:smash: :seeya
Old Oct 1, 2003 | 05:56 AM
Brutus's Avatar
Brutus
Default Re: Plug wire routing (NHvette)
Over the top. Looks neat when you make a feature out of them.
Old Oct 1, 2003 | 06:23 AM
Jvette73's Avatar
Jvette73
If you go over the valve covers like i did, it usually means ditching the factory ignition wire shielding. At least the parts that run underneath. When I did this it had a negitive effect on radio reception, which ws one of the main reasons for the ignition wire shielding. Unlike a steel body car, the vettes fiberglass wont absorb the ignition noise. So if you want to maintian good radio reception, keep the routing and shields as close to factory as possible.
Old Oct 1, 2003 | 06:38 AM
UKPaul's Avatar
UKPaul
Default Re: Plug wire routing (Jvette73)
With Dynomax Headers I routed my wires underneath as stock ('81). No problems with burning the wires or boots.
Brutus,
Nice looking motor :thumbs: Did you make those vacuum pipes yourself?
:cheers:
Old Oct 1, 2003 | 07:05 AM
Brutus's Avatar
Brutus
Default Re: Plug wire routing (UKPaul)
:cheers:
Yeah Paul I did them myself. I used 1/4" stainless tubing for the job. Still got a couple of lines left to finish off before I'm done tho.
Thanks for the compliment too btw.
Bob
Old Oct 1, 2003 | 04:08 PM
mox 77's Avatar
mox 77
Default Re: Plug wire routing (Brutus)
Brutus:
Looks great...I am using the same wire looms. But, I'm curious about your
choke plumbing. How does it work?
Thanks, Bill
Old Oct 1, 2003 | 06:59 PM
1972 Shark's Avatar
1972 Shark
DP77Vette,
Said I'd let you know how the install went. Just finished the install of Rapid Fire Plugs and new Pertronix Flame Thrower Wires. I routed the wires in the original looms (under the headers) and am still using the ignition shielding top cover and both side pieces. The install went fairly easy, the pasenger side was a little more difficult as I have Air Cond on that side. The shielding was a little bit of a pain too but I think its worth it. The motor is running smooth as silk after the install. I'll take her out tomorrow and put her through the paces on the back roads. Good luck with yours!
:smash:
WOOD
Corvettes were meant to be driven, not sit idle! So drive yours today "like you stole it."
:steering:
1972 Ontario Orange, Dark Saddle 350, TH400, Hookers, Edelbrock Performer, 2.5" exhaust w/Flowmasters, Pertronix Ignitor Ignition, Now Pertronix Flame Thrower Wires and Rapid Fire Plugs & a few other bolt on items. She's coming along slowly but surely
[Modified by 1972 Shark, 7:00 PM 10/1/2003]
[Modified by 1972 Shark, 7:10 PM 10/1/2003]
Old Oct 1, 2003 | 07:17 PM
Brutus's Avatar
Brutus
Default Re: Plug wire routing (mox 77)
Brutus:
Thanks, Bill
Bill...It works just the same as it always did. I've changed nothing from it's original plumbing except that it no longer runs via the heat cross over in the manifold.
Bob
Old Oct 1, 2003 | 08:20 PM
1972 Shark's Avatar
1972 Shark
:thumbs: Great Color combo, Blue & Gold on the motor. How much is gas where you are?
To Plug wire routing
