383's
Old Oct 3, 2003 | 08:26 PM
warhovs's Avatar
warhovs
Default 383's
Just a few questions:
1) If I go with an internally balanced crank, can I keep my stock diameter damper?
2) If I don't go internally balanced, I assume the larger damper will require a mod to my timing cover (due to the pointer location)?
3) On externally balanced, any problem using a balance plate on my stock flywheel?
4) Angle plug vs straight plug on World Sportsman IIs with Dynomax headers, either one better for spark plug clearance?
Thanks! :chevy
Old Oct 3, 2003 | 08:35 PM
fauxrs's Avatar
fauxrs
Default Re: 383's (warhovs)
Yes
No modification required, just buy a new pointer for the correct diameter
not so long as you have the assembly balanced with the flywheel, plate and dampner at a machine shop....
Straight..no reason to go with angle plugs
Thanks! :chevy
Hey...no worries..... :cheers:
Old Oct 3, 2003 | 09:29 PM
rob75383's Avatar
rob75383
Thanks! :chevy
I don't know about clearance issues, but I have heard that angle plug heads give and extra performance boost due to the plug being closer to the exhaust valve. I don't know if the boost comes from the way the flame travels or from the way that the cylinder swirls.
I have seen in magazines that some headers need clearancing whether or not they are straight or angle plugs. All they do is heat up the spot with a torch and indent the pipe slightly, then they use some of those shorty plugs that are on the market nowadays, to get the clearance that's needed.
Old Oct 3, 2003 | 09:32 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Re: 383's (fauxrs)
What is the purpose of angle plugs on heads? :confused:
To 383's
