Leaking Freeze Plug
Old Oct 6, 2003 | 05:56 PM
virtue4u's Avatar
virtue4u
Default Leaking Freeze Plug
It leaks about 1/2 cup of water on every drive. Is there an easy fix? Or does it need to be replaced? If it must be replaced, how do I do that?
Old Oct 6, 2003 | 06:01 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Leaking Freeze Plug (virtue4u)
if you can get to it from the bottom, then they are not that bad to replace.
Drain the cooling system and then drill into the middle of the plug. Pry the plug out. They make plug pullers, it's a u shaped tool with a threaded puller in the middle.
Once the plug is out, use a seal driver or the right sized large socket and a hammer to pound the new one in. Some use some RTV around the replacement one for a good seal. they also make rubber expandable ones, but I would consider that a temporary fix.
Old Oct 6, 2003 | 06:30 PM
flood's Avatar
flood
Default Re: Leaking Freeze Plug (BSeery)
I think I may have a leaky freeze plug too. The only problem seems to be the tight quarters its located at. Between the firewall and block.
Old Oct 6, 2003 | 07:17 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Re: Leaking Freeze Plug (flood)
I believe BSeery was speaking of the freeze plugs in the side of the block by the cylinder walls. Of hand, I can't think of any easy way of changing out the one's in the back of the block.
Old Oct 6, 2003 | 08:03 PM
java0881's Avatar
java0881
Default Re: Leaking Freeze Plug (bgrice)
i replaced the one behind the starter last winter without pulling the motor.it was a real pain in the ... but it can be done.had to remove the header/sidepipe
best advice: ADD ANTIFREEZE.
Old Oct 16, 2003 | 12:31 AM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Nope - decide which is easier - pull the motor or drop the trans. That is the only way to get at the ones in the back.
To Leaking Freeze Plug
