Oil pans...
Old Oct 8, 2003 | 09:18 PM
ZD75blue's Avatar
ZD75blue
Default Oil pans...
Hey guys...
I'm looking to upgrade the oiling system on the 75... that and the pan holds about a quart less due to a golly whopper of a ding (ok so the whole bottom is smashed in... to the point of wondering how it doesnt leak from a crease... at least somewhere!)
I'd like to keep it very budget, but have the ability to make a U-turn an keep oil on the sump. Well ok, I'd love to set it up for corner carving and acceleration... just cheaply.
I've read that the stock preasure pump is just fine for most applications, so I'm thinking a blueprinted stock preasure... but I've also heard that the Z28 style pump is the way to go. On our car's did they recieve a high perf pump from the factory? Or do ours contain the same stuff as a caprice of the same year?
That said, I'll prolly go with the over kill route: Melling Z28 pump... but that still leaves the oil pan! Is it true that ours have a different shape in order to clear the steering? If so whats an step above stock when it comes to replacements?
Thanks for the point in the right direction!
:cheers:
Old Oct 8, 2003 | 09:22 PM
ZD75blue's Avatar
ZD75blue
Default Re: Oil pans... (ZD75blue)
Question 2:
Is it worth the money to upgrade the oil pump shaft? I'm frugal... well um... ok so I'm Cheap! :jester
The motor had 70k on it when torn down... I'm thinking about replacing it only for the 13 dollars... :smash:
Old Oct 9, 2003 | 10:35 AM
ZD75blue's Avatar
ZD75blue
TTT
Old Oct 9, 2003 | 05:33 PM
KenSny's Avatar
KenSny
Well now, if that's really true you'd be thinking of hammering out the dented pan. A good ball-peen or body hammer and a coat of paint would fix it right up...... ;)
Old Oct 9, 2003 | 06:09 PM
ZD75blue's Avatar
ZD75blue
Default Re: Oil pans... (KenSny)
Well... if it says anything I woulda already done it... but even to my eyes its to beat up to pound it back out! :cheers:
So what brands etc do you guys trust/run? :cheers:
Old Oct 10, 2003 | 06:22 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Moroso or Milodon are both a good choice. If $ was a big deal, then Stef's of Canton would be next my choice ;) . I see you found the oilpan topic in the Engine Mod section :)
Old Oct 10, 2003 | 09:53 AM
KenSny's Avatar
KenSny
Summit sells a pan that's almost a dead-ringer for the stock pan. I don't know if it has baffles or not. I'm not sure if you have an L82 but if you do and the replacement pans has a baffle built in then you might need to remove the L82 baffle that is mounted to the main caps.
If you think the oil pump is bad then now's the time to replace it. Get a one piece gasket for the pan - sure is a lot easier to install than the 4 piece set.
Almost forgot. While you are down there replace the rear main seal - cheap and easy to do.
[Modified by KenSny, 9:57 AM 10/10/2003]
[Modified by KenSny, 9:58 AM 10/10/2003]
Old Oct 10, 2003 | 09:58 AM
Fevre's Avatar
Fevre
What ever you do do NOT get a Wysco oil pan, the quality as **** poor and I sent it back to get a Milidon stock replacement.
Old Oct 10, 2003 | 02:41 PM
ZD75blue's Avatar
ZD75blue
Default Re: Oil pans... (Fevre)
Yup I found the oil pan topic... but the search tool didnt!
Thanks for the recomendations...
The block is from an L48, So's the car but the engine wont be for long!
I'm thinking about the milodon hamburger style... or a stock replacement, I cant figger which would work best for a basic rebuild + heads/cam/headers... I would love to be able to pull some g's in the corners (Note: Ok so it may not be a g... but enough to get the butt sliding :jester )
So far I'm leaning more towards stock replacement, but the baffles... alas, parts books and I dont go well! I'll drool in em till the day comes to order, then stall and perfect everything :confused:
To Oil pans...
