Quadra-Jets, all the same?
Old Oct 13, 2003 | 03:56 PM
467-Ratman's Avatar
467-Ratman
Default Quadra-Jets, all the same?
I am looking for a Quadra-Jet for my motor, question are they all the same or is there one that would be better for my big block? Also was told that a marine Q-jet was good too for performance, but does not have a choke.
Old Oct 13, 2003 | 04:03 PM
Gordonm's Avatar
Gordonm
Default Re: Quadra-Jets, all the same? (467-Ratman)
No they are not the same at all. Different size jets, oumps and there was even different cfm. Normal is 750 cfm and I think it was 800 or 830 was the bigger one. Check with Lars on this. Qjet guru.
Old Oct 13, 2003 | 04:07 PM
Fevre's Avatar
Fevre
Wish you where closer to me, I'd let you try out my 750 dp to see if you like it any better.
Old Oct 13, 2003 | 04:27 PM
Larry B.'s Avatar
Larry B.
There are literally hundreds of different Q-jets. Many have the fuel inlets in the front. Some have chokes on the carbs while others use a divorced choke. Over the counter Q-jets are absolute junk and may never work. You can get a new Q-jet from edelbrock. Pick one from ther list. Then get Lars Q-jet tunning paper from http://www.corvettefaq.com and set it up for you application. It is worth the effort.
Old Oct 13, 2003 | 05:26 PM
467-Ratman's Avatar
467-Ratman
Default Re: Quadra-Jets, all the same? (Fevre)
Fevre, Appreciate the thought, I may end up with a 750DP, I have been talking to a lot of guys lately about the Q-jet and when tuned right it sounds like a great carb. The place I bought my 850 from said they would let me trade it back on any other carb so thats most likely what is going to happen. It will make a good winter project to change it!
Old Oct 13, 2003 | 09:01 PM
74ZZ430's Avatar
74ZZ430
I've been doing a lot of research on quadrajet recently,since I'm still using one on a ZZ430 clone and very happy with it. From what I can tell most q-jets were 750 cfm except the ones used on big block Buicks, Pontiacs and Oldsmobiles beginning in about 1971 which were 800 cfm, larger primarys. The problem with these units they are all center fuel inlets, although I have seen adapters to make them side inlet, and you would have to modify your linkage for a chevy.
You also want to get a 1974 earlier Q-jet , since 75 and later are harder to modify for performance. Most Q-jet shipped on small blocks the secondary air valve is limited to 70% opening and the big blocks open to 80 to 85% , although this can be easily modified by grinding the factory stop. Lars has been extremely helpful with answering some questions I had.
Old Oct 14, 2003 | 09:22 PM
LT1driver's Avatar
LT1driver
Default Re: Quadra-Jets, all the same? (74ZZ430)
The cfm was determined by how much the rear secondary was allowed to open, higher cfm used full opening and lower cfm had linkage set so secondary was restricted. :cheers:
Old Oct 16, 2003 | 07:52 PM
Kevin Mason's Avatar
Kevin Mason
Default Re: Quadra-Jets, all the same? (LT1driver)
Stupit questions, but:
Can a quadrajet designed for an auto be made to work on a car with a manual?
Which quadrajets will work with '69 small block fuel inlet, linkage, etc.?
[Modified by Kevin Mason, 6:55 PM 10/16/2003]
To Quadra-Jets, all the same?
