Distributor Question
Old Oct 22, 2003 | 12:29 AM
69toy4me's Avatar
69toy4me
Default Distributor Question
I have a 69 corvette, 350 4 speed. It currently has a dual point tach drive in it. I would like to modernize it with hei technology. What is your experiences and recommendations on this? :confused:
Old Oct 22, 2003 | 12:48 AM
blackbirdpilot's Avatar
blackbirdpilot
Default Re: Distributor Question (69toy4me)
I have the same set up. Accel dual point tac drive, no VA. I've thought about the going to a HEI, but I think it would be easier to go with a drop in unit like the pertronix II. I have the pertonix I on another car. No problems so far. Never have to set points again, and I believe it will be cheper than and HEI Tac drive. Most likely will need to adjust the timming curve on the HEI and get the correct VA unit to fit your needs.
Good luck!
:flag
Old Oct 22, 2003 | 08:43 AM
1LE's Avatar
1LE
I have the Crane XRi unit in my 74, Installed it a few months ago. no problems so far.
Old Oct 22, 2003 | 09:29 AM
Surfer69's Avatar
Surfer69
I had Pertronix but went back to points. Really not a big deal keeping points.
Old Oct 22, 2003 | 09:57 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I installed the Breakerless SE points replacement kit during July 4th weekend. I love it. Car has never run better. A bit pricier than similar kits, but uses the existing coil wire only. Good luck with your decision. :seeya
Old Oct 22, 2003 | 11:11 AM
ROD NOCK's Avatar
ROD NOCK
Drop in an HEI, and convert your tach to electronic. Many good HEI units avail. If budget concerns, purchase a used HEI dist and tach, rebuild dist. :chevy
Old Oct 22, 2003 | 11:34 AM
stpman's Avatar
stpman
Default Re: Distributor Question (ROD NOCK)
Not to hijack this thread but I have a unilite tach drive in my 74, can this be used (or modified to be used) with a Tuned Port setup?
Steve :steering:
[Modified by stpman, 11:35 AM 10/22/2003]
Old Oct 22, 2003 | 03:52 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
HEI is nice, but if you have the money a MSD set up with their tach drive distributor and a 6 box is nice. I am personally been through a points distributor with my original motor, a HEI with the ZZ4, and now I am going to a MSD with a digital 6 box cause I want my original cable driven tach back.
Old Oct 22, 2003 | 06:55 PM
guvnerwl's Avatar
guvnerwl
St. Jude Contributor
I'm running a DUI HEI with mech tach drive on a '70 BB. No problems.
Old Oct 22, 2003 | 11:07 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
:seeya How about "Mallory Comp 9000" it's just like a Mallory Unilite but it's a one piece billet distributor. :yesnod: I just happen to have one for sale... :D
Old Oct 23, 2003 | 12:41 AM
OneHotV6's Avatar
OneHotV6
Default Re: Distributor Question (Intimidator454)
Just curious if anyone has switched from points to the Ignitor or Ignitor II replacement?
Old Oct 23, 2003 | 02:35 AM
blackbirdpilot
Default Re: Distributor Question (OneHotV6)
Not on the vette (yet), but on another car. So far no probs.
Old Oct 23, 2003 | 08:30 AM
Sigforty's Avatar
Sigforty
I had an Ignitor 2 it left me stranded one night. I had to get a ride back to my place to get all the points and original distributor stuff. I then proceeded to pull the distributor and repalce the guts and stab it back on the side of the road. It was not my idea of fun, and I think it was mostly due to the design of the Ignitor 2. The rivets that hold the pickup had some how worn loose and caused it to go out of clearance. The unit was only 3 months old when this happened.
Old Oct 23, 2003 | 08:37 AM
pws69's Avatar
pws69
I switch my '69/350 to an Ignitor about a year ago and have had no problems at all. Always starts right up and idle is rock solid.
Old Oct 23, 2003 | 09:48 AM
Surfer69's Avatar
Surfer69
Default Re: Distributor Question (pws69)
pws69, just remember not to leave key turned to fwd position for more than a minute or it will fry. Ask me how I know! Ignitor II doesnt have this problem I've read.
To Distributor Question
