Just ordered a Crankcase evacuation system...
Old Oct 22, 2003 | 02:53 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Just ordered a Crankcase evacuation system... (Pete79L82)
A friend of mine runs his breathers directly into a overflow container without it being hooked up to the vacuum system or exhaust and he has no oil leaks...
I also know several people that just run breathers without a hooked up PCV system and they have no issues either...
Olivier; You are missing the intended purpose of that system. It is designed to scavenge the air out of the engine. Not just as a breather. A breather will only allow the engine to achieve "zero" (atmospheric) pressure. An evac system like this is designed to create a vacuum in the engine. When you create a vacuum (negative pressure) in the engine the rings will seat better and you will help to eliminate the oil cloud in the pan. On our short track motors will try to maintain 7" of vacuum. On a Cup motor we try to maintain 15" of vacuum. The Moroso kit will achieve about 2" of vacuum with a good designed header at WOT. The more vacuum you can maintain in the crankcase the more power the engine will make.
If all you want to do is to use it as a breather then just putting a hose in a catch can will work fine. But that will only get you to zero pressure, not to vacuum.
Pete
Sounds interesting... However - the power you gain by having more vacuum - you'll lose by recirculating hot air into the system...
There must be a reason that no serious performance car at the track has a PCV system hooked up.. Many of the cars there use a similar system like I ordered... If you'd get better performance with with the PCV system - why isn't everybody using it at the track :confused: :confused:
[Modified by GrandSportC3, 2:54 PM 10/22/2003]
Old Oct 22, 2003 | 03:02 PM
Pete79L82's Avatar
Pete79L82
Default Re: Just ordered a Crankcase evacuation system... (GrandSportC3)
You misunderstood me. The Moroso system will create a vacuum, not a pvc valve. A pcv does not have the volume to create a vacuum. At best a pcv will only get you to zero pressure at WOT, and that would have to be on an exceptionally sealed motor. A pcv works great on the street but has no use at the track. Your Moroso kit will work good at the track but I am not sure one way or the other if it will work on the street.
Pete
GrandSportC3
Here's a pic of a Dragster engine with the evacuation system...
Old Oct 22, 2003 | 03:05 PM
GrandSportC3
Pete
Ok - I understood that you'd get 7" of vacuum with the PCV system... Thanks for the information!! :thumbs: :thumbs:
Old Oct 22, 2003 | 03:12 PM
Fevre's Avatar
Fevre
Why not rig it up to run both, pcv when driving on the street then switch to the vac system when racing. If you have a breather you will get fumes coming out at idle if you do not have some vacuum, try pinching your pcv line off to see what I mean. Of course if essence of burnt oil is your preferred cologne then don't run the pcv for street driving.
Old Oct 22, 2003 | 03:38 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (Fevre)
It's actually the opposite on my car..... Oil gets sucked into the engine through the PCV system...
Old Oct 22, 2003 | 04:13 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
:leaving:
Old Oct 22, 2003 | 05:06 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
make sure your front crank seal is double sided because the single type is made to seal pressure from inside the crankcase will allow dirt to be drawn into the engine passed the seal. the best way to seal is to put the seal in backwards to act as a vacuum seal. also make sure you use rocker cover gaskets with metal in the center because the high vacuum can suck in the gaskets between the bolts :chevy
Old Oct 22, 2003 | 05:10 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (clem zahrobsky)
Thanks!!! :thumbs:
Old Oct 22, 2003 | 05:33 PM
gkull's Avatar
gkull
GrandSport your doing the right thing. Although pvc is more about emissions of hydrocarbons and keeping the motor more oil leak free.
The amount of hot air drawn through a 3/8th inch tube at low vacuum WOT is miniscule.
I look at my setup and your drawing or venting more air through the K&N filtered breather than that little PVC. No way could the PVC suck enough to ever create an inch of vacuum with a big high flow breather on the valve cover. Then at it's lowest vacuum when the blowby is at it's highest. The beather is venting.
Those race setups like that Dragster you can actually see the clear tubes flowing white oil mist above 3500-4000 rpm
Old Oct 22, 2003 | 06:26 PM
gkull's Avatar
gkull
Default Re: Just ordered a Crankcase evacuation system... (gkull)
I was going to say. When we first welded ours in on the S/C dragster. They didn't seem to work very well. So we were talking to some other racers in the pit's and they said angle and the depth of the tune in the collector are critical to get the max venturie effect. It's been a long time. But we placed it at near 45 deg to the collector and near the center of flow 8-10 inches after the 4 tubes merge.
Then you can get so much suction vacuum at high rpm WOT that it acually colapses to evacuation clear tubing. We ended up having to install a stretched out spring to hold the tube open.
:) I tried last night to do some good linelock burn out videos like yours! :( The digi camera i used goes into decible overload very easy so they sound hoarible
Old Oct 22, 2003 | 07:54 PM
GrandSportC3
I expect some kind of oil mist on my setup too.. The stroker engines produce a lot of crankcase pressure...
Old Oct 22, 2003 | 07:56 PM
  #33
GrandSportC3
post the videos.. It doesn't matter how it sounds!!!
Old Oct 22, 2003 | 09:08 PM
  #34
gkull's Avatar
gkull
I meant to say " the tube in the collector "
Yours and "BeachBums" 383 from the C-4 section which is a consistant 11.50 car do some impressive burnout posted videos.
My Buddy left his old 89 Vette wheels at my house after helped him install his new wider wheels. They were the 275/40/17 Goodyear KDW's or something like that. So I mounted the rears and did a couple of 100 mph rear tire line lock burnouts in a parking lot. I'm going to get a good cameraman and digi video camera and try again soon.
Old Oct 22, 2003 | 09:15 PM
  #35
GrandSportC3
I usually do my burnouts usually at around 45 mph...
Old Oct 22, 2003 | 09:19 PM
  #36
63Banshee's Avatar
63Banshee
I use rubber gaskets and adhere them to the valve covers using emblem adhesive. This helps keep them in place during installation as well. :thumbs:
Old Oct 22, 2003 | 09:30 PM
  #37
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (63Banshee)
:thumbs: :thumbs:
To Just ordered a Crankcase evacuation system...
Old Oct 22, 2003 | 11:36 PM
  #38
JoeC427's Avatar
JoeC427
I'm running that same Moroso System on my car. It works fine on the street. I used #12 braided line, and Russell fittings for the evac.
later,
Joe
Old Oct 22, 2003 | 11:42 PM
  #39
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (JoeC427)
later,
Joe
I actually ordered the cheaper Mr. Gasket system which is basically identical to the Moroso system...
Old Oct 23, 2003 | 12:21 AM
  #40
stinky's Avatar
stinky
Olivier, why not speak with Dave Bacher, owns early C3 known as "Bruiser", has bb with same evacuator as you've choosen. He's at http://www.tropiczoneracing.com
Another alternative would be to install a belt driven vacuum pump setup.
