Just ordered a Crankcase evacuation system...
Old Oct 22, 2003 | 11:56 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Just ordered a Crankcase evacuation system...
Right now - I have my PCV valve hooked up to the carb.. which sucks oil and hot air into the engine... I decided to get a Vacuum evacuation system that hooks up 2 breathers to the collectors (headers)...
Does anybody else run such system??
http://store.summitracing.com/partde...art=MRG%2D6002
[Modified by GrandSportC3, 11:57 AM 10/22/2003]
Old Oct 22, 2003 | 12:11 PM
BeaterShark's Avatar
BeaterShark
Default Re: Just ordered a Crankcase evacuation system... (GrandSportC3)
I had considered it at one time, but read that it is only effective when running open headers or race mufflers.
Old Oct 22, 2003 | 12:13 PM
Xracer's Avatar
Xracer
Default Re: Just ordered a Crankcase evacuation system... (BeaterShark)
Absolutly true, not good for a street car.
Old Oct 22, 2003 | 12:47 PM
GrandSportC3
I run open sidepipes.. so it'll work great for me :party: :party:
Old Oct 22, 2003 | 01:04 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
I run it on my Chevelle! Works good. It will work on a car with mufflers also. All it does is vent it out the headers and through the mufflers..
-Rick
Old Oct 22, 2003 | 01:07 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (cicch95)
-Rick
:iagree:
I just don't want to re-circulate the hot air and oil from the crankcase...
Old Oct 22, 2003 | 01:10 PM
Pete79L82's Avatar
Pete79L82
They have to go into the collector. Do not try to put them into a primary pipe or you will not get any scavange from them. The fact that you have side mount headers means that you will have to mount them outside of the car to get them into the collector. Also order an extra set of valves as they have a tendancy to blowout easily.
Old Oct 22, 2003 | 01:34 PM
sb69coupe's Avatar
sb69coupe
Is this really an effective system for street use? I can see how it would work for short WOT passes, but at part throttle cruise or during normal driving, I can't see that the exhaust will pull enough vacuum to evacuate the crankcase gasses very effectively. Seems to me like a case of a race setup that would not be particularly suited for street use.
:confused:
Old Oct 22, 2003 | 01:37 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (Pete79L82)
I will mount the tube that needs to be welded to the collector on the bottom towards the inside...
Old Oct 22, 2003 | 01:41 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (sb69coupe)
:confused:
Well - if you are not running WOT - the crankcase pressure won't be too high and the system will just act like regular breathers...
Old Oct 22, 2003 | 01:45 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
He does a lot of drag racing. I think thats the main purpose of this vette. Beside he's got a nice C5 to cruises in. :thumbs:
Old Oct 22, 2003 | 01:52 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (Van Steel)
:yesnod: :yesnod: My C3 is mostly driven from and to the track and to Cruises... I'm actually thinking in starting to trailer the car to the track.. I still have to get a SUV to be able to pull the trailer.. As soon as I get a SUV - I will rent a trailer and trailer the car to the track.. It's not because the car won't make it to the track.. but if something breaks - I won't have to pay hundreds of $$ to the towing company...
Another problem is that I don't really want to drive the car for 240 miles in the "track setup" to the track... The front skinny wheels as also the ET Streets on the back aren't really made for the street and the space in the car is very small to carry all those tires in the car...
[Modified by GrandSportC3, 1:53 PM 10/22/2003]
Old Oct 22, 2003 | 02:01 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
Default Re: Just ordered a Crankcase evacuation system... (Xracer)
Yeah, not good on a street car cause there is no evacuation at low RPM and you need a very low backpressure exhaust system for it to work.
You haven't wasted your money though. I ran a combination evacuator and pcv system on my 64 S/S Dodge and it worked pretty well. The pcv does its thing at low rpm and the crankcase evac performed pretty well while racing.
How did I know? I fabricated my own oil pan and it had pinhole leaks after the first attempt. It did not leak at high RPM... that's some internal low pressure working.
I'll try to dig up some pictures of the system I made if your interested.
[Modified by 63Banshee, 1:04 PM 10/22/2003]
Old Oct 22, 2003 | 02:04 PM
Pete79L82's Avatar
Pete79L82
That is not correct. The engine will have blowby at all RPM's. That is the nature of all motors. The valve will not open until the pressure on the valve cover side is greater than the pressure on the collector side. At wide open throttle there is low pressure in the exhaust. (laws of physics - Faster moving air have less pressure than slow moving air) This will cause the valve to open, scavanging the blowby pressure. At lower RPM the exhaust has higher pressure. The blowby pressure has to exceed the exhaust pressure before the valve will open. If the blowby pressure become to high then you will end up blowing out the valve cover gaskets or pushing oil past the rear main seal.
I used to use them on the dyno before better stuff came along. The worked well for what they are. but I don't know of anyone that used them on a street driven car.
Pete
Old Oct 22, 2003 | 02:06 PM
GrandSportC3
Default Re: Just ordered a Crankcase evacuation system... (63Banshee)
Why would you need a lot of evacuation at low RPM's?? The pressure at low RPM's is not too high... so evacuation isn't needed as much as with WOT...
Anyway - I run open pipes and basically have no backpressure in my exhaust system... so the system will work great for me!
[Modified by GrandSportC3, 2:08 PM 10/22/2003]
Old Oct 22, 2003 | 02:10 PM
63Banshee's Avatar
63Banshee
Why would you need a big deal of evacuation at low RPM's?? The pressure at low RPM's is not too high... so evacuation isn't needed as much as with WOT...
I think you missed the point. The pcv system is used at low RPM. You need this on a street driven car. You have low backpressure exhaust, good. With the evac system you will only vent the crankcase at high RPM.
Do it your way and let us know what your spark plugs look like after a few trips around town.
Old Oct 22, 2003 | 02:15 PM
sb69coupe's Avatar
sb69coupe
As pointed out, there will be pressure at all RPM ranges. It's not the backpressure of the exhaust that effects the vacuum on the system, it's the venturi effect of the exhaust stream going past the fitting, causing a vacuum to scavenge the gasses.
You keep saying that "the system will work great for you", despite what others here are pointing out. The vendor states that this system is oriented for drag race use. Didn't you just drive your '68 across the state for a show last weekend or so? If you're turning the car into a race car, then you'll likely be OK. If you're going to continue driving it on the street, I predict oil leaks in your future.
Just my $0.02. I'm no engine builder by any stretch of the imagination. I feel sure that GM didn't just put PCV systems on these cars to handle WOT crankcase pressure issues.....
To Just ordered a Crankcase evacuation system...
Old Oct 22, 2003 | 02:16 PM
GrandSportC3
I'm more concerned about power at the track than my spark plugs.. Plugs are cheap and easy to change... (takes me 5 minutes or less to change all my plugs)... ANY hot air getting into the combustion chamber will reduce power... The air coming from the pcv valve is hot AND oily... I don't really want to get that kind of air into the combustion chamber... The oil through the PCV system isn't good for the plugs either...
Old Oct 22, 2003 | 02:21 PM
GrandSportC3
A friend of mine runs his breathers directly into a overflow container without it being hooked up to the vacuum system or exhaust and he has no oil leaks...
I also know several people that just run breathers without a hooked up PCV system and they have no issues either...
[Modified by GrandSportC3, 2:29 PM 10/22/2003]
Old Oct 22, 2003 | 02:48 PM
Pete79L82's Avatar
Pete79L82
Olivier; You are missing the intended purpose of that system. It is designed to scavenge the air out of the engine. Not just as a breather. A breather will only allow the engine to achieve "zero" (atmospheric) pressure. An evac system like this is designed to create a vacuum in the engine. When you create a vacuum (negative pressure) in the engine the rings will seat better and you will help to eliminate the oil cloud in the pan. On our short track motors will try to maintain 7" of vacuum. On a Cup motor we try to maintain 15" of vacuum. The Moroso kit will achieve about 2" of vacuum with a good designed header at WOT. The more vacuum you can maintain in the crankcase the more power the engine will make.
If all you want to do is to use it as a breather then just putting a hose in a catch can will work fine. But that will only get you to zero pressure, not to vacuum.
Pete
