AC POA valve conversion
Old Oct 22, 2003 | 02:37 PM
GR8T WYT's Avatar
GR8T WYT
Default AC POA valve conversion
Has anyone tried converting their POA valve to Clutch Cycling Orifice Tube operation. I've seen a conversion kit for about $99.00. If so did it improve the cooling ability of the system?
Thanks, Bob
Old Oct 22, 2003 | 03:47 PM
zwede's Avatar
zwede
Default Re: AC POA valve conversion (GR8T WYT)
If your POA system works, keep it. It's my understanding the CCOT conversion is not an upgrade, but rather is for when your POA valve is busted and you can't find a new one. They're very hard to get a hold of these days.
Old Oct 22, 2003 | 09:23 PM
vettfixr's Avatar
vettfixr
I've got the VIR eliminator but haven't installed it yet. I'm curious to see what responses you get on this post.
Old Oct 23, 2003 | 08:02 AM
markdtn's Avatar
markdtn
Default Re: AC POA valve conversion (vettfixr)
I've not done a Corvette with one, but have done a 68 Camaro (R12) and a 68 Firebird (R134). Both customers were still happy with the conversion last I spoke with them.
Old Oct 23, 2003 | 08:10 AM
GR8T WYT's Avatar
GR8T WYT
I've discovered thru research that the POA valve has an adjustment screw located inside the valve that controls the pressure at the valve. If you convert to 134A you need to turn this screw a 1/4 turn counterclockwise. R-12 likes 29.5 PSI and R134A likes 26.5 PSI. The adjustment should show 10 degrees +or- lower temps at the vents provided the rest of the system is in good working order. I bet not to many people or AC techs know about this procedure and therefore blame the134A for the poor cooling. I'm going to try this before I go switching valves but not till next spring when I plan to do some serious engine detailing and will open up the AC system to remove it. If anyone attemps this in the near future let us know the results. Bob
Old Oct 23, 2003 | 08:37 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
If possible stay with the POA. The fixed orifice is not as efficient as a variable orifice. The POA or an expansion valve will be more efficient at varying engine rpm’s, as it will adjust for the change. I have read that an aftermarket company has designed and marketed a variable orifice to replace the GM fixed orifice the reviews that I read looked good.
Just my 2 cents.
Old Oct 23, 2003 | 10:30 AM
Wrencher's Avatar
Wrencher
I stuck with the (adjusted) POA variable orafice to prevent cycling while driving. Also, I'm not sure if the A-6 would hold up with a cycling system, even though it's probably THE toughest compressor ever.
Hans
To AC POA valve conversion
