Headlights
Old Oct 22, 2003 | 07:12 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Headlights
I won a pair of aftermarket headlights on ebay for my 81 and was wondering about the headlight bulb size. It came with H4's with a sealed beam headlight housing. Will these fit my year? Here is a link to the ebay auction.... http://cgi.ebay.com/ebaymotors/ws/eB...tem=2436841363
Old Oct 22, 2003 | 10:36 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Headlights (ElectronBlueC3)
I don't see any reason why they won't fit. I bought a similar set from JC Whitney and had to modify the tabs slighty so they would fit in the buckets but otherwise they work great. Soooo much brighter.
Old Oct 22, 2003 | 10:46 PM
PewterMetallic98
Default Re: Headlights (burners)
Well my question really was if the H4's plugs into the stock bulb harness that came on an 81? I hope they are the right bulbs....
[Modified by ElectronBlueC3, 9:47 PM 10/22/2003]
Old Oct 23, 2003 | 12:12 AM
SharkBit's Avatar
SharkBit
ive also got a set...they will fit...
good luck!
Old Oct 23, 2003 | 03:07 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Headlights (SharkBit)
I wonder if he has anymore????
Old Oct 23, 2003 | 12:47 PM
PewterMetallic98
Default Re: Headlights (Desertdawg)
Yea, i'm sure he does. It is a company called makauto.com. Go check them out and see what you can find. Email them through the ebay auction that I have linked too. Good Luck!
Old Oct 23, 2003 | 01:10 PM
75stinger's Avatar
75stinger
:yesnod:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
Old Oct 23, 2003 | 01:42 PM
pws69's Avatar
pws69
J.C. Whitney sells several different versions of these Halogen Conversion lights. I have purchased them from them in the past for different vehicles (Jeeps, my Harley) and they work fine - some are less money (especially when it comes to the outrageous "shipping and handling" fee this guy wants.
As usual, be VERY careful with eBay.....
Old Oct 23, 2003 | 02:15 PM
Shrike's Avatar
Shrike
I have been wanting to update the headlights on my C3 for a while now and this looks pretty good.
A couple of questions:
Is there a noticeable difference between these and the sealed beam headlights (brightness-wise)?
Do you just buy 4 lights? is there a difference between hi and low?
Just to be crystal clear- the H4 bulb will use the same plug that the stock headlight does?
thanks in advance!
Scott
Old Oct 24, 2003 | 03:19 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Headlights (Shrike)
Ok guys, I emailed Makatoautotrends.com, the H4 bulb is a dual filament bulb. How do you make this work on our vettes where we use 2 seperate lights for high and low???????
Old Oct 24, 2003 | 09:09 AM
SharkBit's Avatar
SharkBit
you can just wire up the plug to energize both elements on the inside (high) beams when the dimmer switch goes to high.
i would suggest the use of relays
also, this is what im going to do to mine :cheers:
Old Oct 25, 2003 | 12:12 AM
PewterMetallic98
I bought two sets of these and only one set will fit the car. The high beams have 2 prong instead of 3 prongs like the other low beams. Anyone interested in these? They are brand spanking new! Let me know if you are interested. Thanks
PS: I wish there was an adapter to go from three from to two prong. Any ideas??
Old Oct 25, 2003 | 02:40 AM
BB wowbagger's Avatar
BB wowbagger
Why not buy a Xenon kit?.. :cheers: :cheers:
To Headlights
