L-88 airbox setup help
Old Oct 23, 2003 | 03:31 PM
467-Ratman's Avatar
467-Ratman
Default L-88 airbox setup help
I have a L-88 style hood and was wondering about changing over to the true style with the box and special air cleaner base. Has anyone done this and what type of intake do I need to have. My intake now is a GM Aluminum dual plane style. Thanks for the info!
Old Oct 23, 2003 | 03:41 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Default Re: L-88 airbox setup help (467-Ratman)
It should work fine as long as it's not a hi-rise. The L-88 dropbase works with almost any 5-1/8" carb and is perfect on the 850DP. The air chamber will mate to a 1" thick foam seal ring that comes as part of the breather assembly. That allows for some misfit on height.
You should be good to go.
Dave
[Modified by Rolling Thunder, 2:42 PM 10/23/2003]
Old Oct 23, 2003 | 03:50 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Don't know how much taller a big block is but FWIW a small block with a RPM manifold, Holley 4150 and a 1" spacer is perfect.......
Old Oct 23, 2003 | 10:05 PM
gearheadz's Avatar
gearheadz
I have the L88 hood w/airbox but with a small block. I have an info page on my site that may be of some value:
http://www.corvetteforum.net/c3/mdsmith/l88.htm
Mark
Old Oct 23, 2003 | 10:19 PM
467-Ratman's Avatar
467-Ratman
Default Re: L-88 airbox setup help (mdsmith)
Mark, Thanks for the help and pictures, great looking engine!!!! :cool:
Old Oct 24, 2003 | 07:53 AM
bigvette1's Avatar
bigvette1
Mark, not only is the engine great but your web site with the links is one of the most comprehensive for cars and vettes around. Everyone should bookmark that page. Well done!
To L-88 airbox setup help
