Strong Gas Smell!
Old Oct 23, 2003 | 11:53 PM
Adam Wartell's Avatar
Adam Wartell
Default Strong Gas Smell!
Often while I am driving I can smell gas.
Then when I get home, as soon as I shut the car off and step out, I smell gas REALLY strong. The smell will linger in the garage for about 6 or 8 hours after shutting off the car.
I do not see any gas leaks on the ground, nor do I see any leaks near the carb.
Any ideas what is going on? One suggestion I got was about some sort of emissions canister, under normal operation, could be causing it. But I never used to smell it before.
Any help would be great!
Thanks!
Old Oct 24, 2003 | 12:22 AM
Fleetwood's Avatar
Fleetwood
Default Re: Strong Gas Smell! (adamw1979)
Theres a vapour cannistor behind the left inner wheel well,black thing with rubber hoses coming off it,could be one or more of the hoses has cracked through,or maybe the vapour hose from the fuel tank has come off.worth checking.
Neil.
Old Oct 24, 2003 | 05:01 AM
rob75383's Avatar
rob75383
I had the same mystery bothering me when I had my 'vette for about 6 months.
I couldn't find ANY signs of leakage, and started to blame the charcoal canister.
What it finally turned out to be was a slightly loose bowl screw on the bottom of the secondary bowl. She would drip on the intake near the distributor, but I could not see any trace of gas anywhere.
The smell seemed the strongest by the passenger door.
I removed the carb for some tinkering and discovered the loose bowl screw.
No gas smell since.
BTW, get a fire extinguisher if you haven't already!!!!
Old Oct 24, 2003 | 07:29 AM
theandies's Avatar
theandies
Default Re: Strong Gas Smell! (Fleetwood)
Neil.
:iagree:
I don't know about 1979's but 1971's have a vapor separator on the left side of the gas tank. There are two rubber hoses back there, one leads back to the tank, the other lead to a hard line that goes to the charcoal canister behind the left side wheel well. I had the gas smell (that was my last project) and I found the rubber hoses at the tank cracked and deteriorated. This vapor separator acts as a check valve also. When you fill the take up completely this valve closed to keep gas from going into the canister. As the fuel level drops, this valve opens and through manifold vacuum the vapors are sucked back to the canister and eventually to the carb. I'd also check that if its on a 1979. I removed my tank and replaced it + all the rubber hoses.
[Modified by theandies, 11:11 AM 10/24/2003]
Old Oct 24, 2003 | 11:13 AM
LABulldog's Avatar
LABulldog
I had a similar problem on my '80 and I removed my fuel vapor canister and replaced the charcoal and the filter on it. The filter can be purchased from NAPA. I solved probably 95% of my gas odor problem. Also, as mentioned previously, check the hoses into and out of the canister for leaks. Good luck.
Old Oct 24, 2003 | 11:32 AM
munday's Avatar
munday
Default Re: Strong Gas Smell! (LABulldog)
i had the same smell, especially when i filled it up at the station, my sender had rusted through so i litteraly had a hole in the gas tank
Old Oct 24, 2003 | 07:48 PM
virtue4u's Avatar
virtue4u
Since you smell gas while driving I doubt that the leak is at the tank, but I had a leak at the rubber hose that connects the tank to the fuel line attached to the frame.
Old Oct 24, 2003 | 08:23 PM
ROD NOCK's Avatar
ROD NOCK
Check those fuel lines at the fuel pump and at the fuel tank sender to body. Could be leaking and evaping before dripping on ground......... :eek:
Old Oct 25, 2003 | 01:56 AM
munday's Avatar
munday
Default Re: Strong Gas Smell! (ROD NOCK)
i could smell mine in the car after filling up and my garage stunk of fuel
Old Oct 25, 2003 | 09:12 AM
Paul L's Avatar
Paul L
The S-hoses at the fuel pump would be my guess. From engine to frame shaking/vibrations they develop cracks where attached to the pump. They do not break but have a nasty habit of cracking and spewing out fuel. It does not show as a drip because of the heat in that area. And it does not show when the car is parked as there is no pressure in the fuel lines. Just wiggle them by hand to diagnose.
To Strong Gas Smell!
