Rusty shock bolts
Old Oct 25, 2003 | 12:47 PM
DaddyO's Avatar
DaddyO
Default Rusty shock bolts
I've been fighting with the right rear upper shock bolt for 2 hrs and can't get the thing off. I tried PB, tried liquid wrench, tried a breaker bar, tried hammering the breaker bar.
The left right was tough too.....but nothing like this. :banghead:
Any ideas or tips?
Old Oct 25, 2003 | 12:52 PM
The Money Pit's Avatar
The Money Pit
Default Re: Rusty shock bolts (DaddyO)
Mine took a torch,2lb mallet and about 12 beers in 8 hours.I only used a propane torch,so it really didn't get the bolt as hot as I'd have liked. :smash: :smash: :smash: :smash:
My mistake,I thaught I read lower shock bolts. The top bolts came right out.
[Modified by The Money Pit, 12:54 PM 10/25/2003]
Old Oct 25, 2003 | 02:26 PM
DaddyO's Avatar
DaddyO
Default Re: Rusty shock bolts (The Money Pit)
If I use an acetlyne torch, do I just heat the bolt and try to move it while it's hot? I've never used a torch to remove a bolt.
Old Oct 25, 2003 | 02:58 PM
The Money Pit
My thinking was to heat the mount to expand the metal and then drive the bolt out with the shock removing tool.Not sure what finally worked. The repeated heating,hammering with the mallet,or the beer.I worked seriously 8 hours on one bolt,and had to replace the shock bolt with a new one anyway.The other side took half the time to change.
I've seen muffler shops heat the manifold flange cherry red to get the stud out without breaking it.That was what gave me the idea.
Old Oct 28, 2003 | 03:35 PM
DaddyO's Avatar
DaddyO
I used a torch on that top bolt and got the nut off from the back, but I still cant get that bolt out! It spins, but won't pull out. There is nothing holding it in the back now. Any thoughts?
Old Oct 28, 2003 | 04:22 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Sounds like it's stuck in the rubber bushing. Can you see if the bushing is spinning too? I haven't changed the shocks on my vette in quite awhile so I don't remember how tough it is to get at the mount. You might be able to cut the bushing with a knife, but I'm not sure. Can you hammer the bolt out? Again, I don't remember how much access you have to that area.
Old Oct 28, 2003 | 04:45 PM
DaddyO's Avatar
DaddyO
Default Re: Rusty shock bolts (Captain Morgan)
It's not stuck in the bushing. The nut spins, but the rubbre does not. It seems to be stuck in the hole.
Old Oct 28, 2003 | 05:24 PM
72GACRZR's Avatar
72GACRZR
Sounds like it might be ruted to a metal tube thru the bushing. Try a long flat nail puller thingy(Ilove them tjingys) and pry it out. :seeya
Old Oct 28, 2003 | 09:05 PM
DaddyO's Avatar
DaddyO
Default Re: Rusty shock bolts (72GACRZR)
What's a long flat nail puller thingy? Like a pry bar?
Old Oct 28, 2003 | 09:10 PM
Captain Morgan
Cruise-In V Veteran
yep
Old Oct 28, 2003 | 09:26 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
There's a steel sleeve in the bushing. That sleeve is about 1 inch or so long. The bolt is likely rusted to the bushing throughout its' length. You might have to cut the bolt....both sides....within the "U" that holds the shock. NOT a fun job. Chuck
Old Oct 28, 2003 | 09:30 PM
DaddyO's Avatar
DaddyO
Default Re: Rusty shock bolts (Chuck Gongloff)
chuck any suggestions how to do that? A sawzall?
Old Oct 28, 2003 | 09:34 PM
Chuck Gongloff
Hacksaw...Sawzall.... Miserable job. Chuck
Old Oct 28, 2003 | 10:09 PM
l2vette's Avatar
l2vette
Sawzall is the answer, cut the Bitch!! DO NOT USE the Torch!!!
:D
Old Oct 28, 2003 | 10:28 PM
DaddyO's Avatar
DaddyO
Default Re: Rusty shock bolts (l2vette)
That's a tight place to get into with a sawzall......
To Rusty shock bolts
