Thinnest Head Gasket???
Old Oct 26, 2003 | 10:23 PM
blunsford's Avatar
blunsford
Default Thinnest Head Gasket???
I am looking for a composition head gasket with a compressed thickness of about .025" instead of the standard of about .038". By my calculations that would give me over .1 compression increase.
This is for a 73 454 and will be used with an aluminum head I'm going to buy. Steel shims are out since they won't work with an aluminum head.
Anyone know where I can find one?
[Modified by blunsford, 4:47 AM 10/27/2003]
Old Oct 26, 2003 | 11:34 PM
rainman69's Avatar
rainman69
Default Re: Thinnest Head Gasket??? (blunsford)
A .022" steel shim is the factory head gasket. The thinnest I've seen is a .015" steel shim.
Summit has both IIRC.
Old Oct 26, 2003 | 11:46 PM
blunsford's Avatar
blunsford
Guess I left some things out. It is for an aluminum head so steel shim gaskets won't work. I'll add this to the original post.
Old Oct 27, 2003 | 12:04 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
chev hi performance talked about using a rubber coated shim gasket that was thin to get more compression on a SBC with AL heads.
i wonder if they make the same thing for the big block.
Old Oct 27, 2003 | 12:07 AM
Titanium Rat's Avatar
Titanium Rat
Default Re: Thinnest Head Gasket??? (turtlevette)
if you need too,,,,,,,deck head and use 38 gasket,,,,,,just a thought (but would be cheaper to og the other route) :yesnod:
Old Oct 27, 2003 | 11:57 AM
1979toy's Avatar
1979toy
Fel-Pro offers a .015 steel shim head gasket that has a coating of some sort to allow for use with aluminum heads for small blocks. I would expect that they offer the same for big blocks. The head and block surfaces must be perfectly flat for these to work so they are really only suitable for use after a rebuild.
I would have to agree with milling the heads to get the compression ratio that you want.
Old Oct 27, 2003 | 12:11 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Thinnest Head Gasket??? (1979toy)
I ended up use GM's, LS-7 BB head gaskets from Scoggins-Dickie. I could find no other suitible gasket for a BB with aluminum heads. Fel-pro makes them too but I think they're also 0.039, identical to GM's. I was at almost zero deck height so I ended up with about a 0.045 quench.
I can get the numbers if you want. I think they were about $30/pr.
To Thinnest Head Gasket???
