1980 Steering and Alignment
Old Oct 27, 2003 | 11:13 PM
azswede1960's Avatar
azswede1960
Default 1980 Steering and Alignment
I have installed new PS valve, cylinder and after having some problems with the tie-arm ends and Pitman arm, the steering is back together BUT I think it needs to get aligned AND get steering wheel back to 12o'clock when going straight.
I am in Phoenix AZ, but will be coming to Sarasota FL in next couple of weeks... any recommendations of shops in either place to fix me up ??
Old Oct 28, 2003 | 01:53 AM
Shark Racer's Avatar
Shark Racer
Default Re: 1980 Steering and Alignment (azswede1960)
If your camber and caster were set perfect before, all you really need is a good toe adjustment (tie rods) and you could head over to any shop to do that really.
-Steve
Old Oct 28, 2003 | 11:47 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
There is a brake and alignment shop on the corner of Country Club and Baseline, North East Corner. They have pretty low prices and do decent work.
Other than them, the only ones I trust are Network Brakes / Alignment. There are in Mesa and Gilbert.
Old Oct 29, 2003 | 08:38 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: 1980 Steering and Alignment (BSeery)
i would definately get it done there before you come to Fl. Thats a lot of miles to put on and you want to make sure your doing them all safely.
Old Oct 29, 2003 | 09:19 AM
azswede1960
Default Re: 1980 Steering and Alignment (Van Steel)
not driving the vette, it is being towed.
Old Oct 29, 2003 | 10:23 AM
Van Steel's Avatar
Van Steel
my bad. I'm about 2 hrs N of Sarasota. I don't really know of any one down there. If need be I have a pretty good place around the corner from me that can do it. They do all of ours. Hopefully someone from that area will chime in.
To 1980 Steering and Alignment
