which headers to buy?
Old Oct 28, 2003 | 01:21 AM
A78Corvette's Avatar
A78Corvette
Default which headers to buy?
I am going to buy ceramic coated headers for a 79 vett. I need advise on which pipes will fit with my A/C ect. I have a 350 engine and automatic trans. I don't have to worry over air tests here. Some liks and advise on good headers will be very helpful. thanks
[Modified by A78Corvette, 6:49 PM 10/28/2003]
Old Oct 28, 2003 | 01:57 AM
Shark Racer's Avatar
Shark Racer
Default Re: which headers to buy? (A78Corvette)
You can go with anything, really. Dynomax(cheap), Hedman or Hooker.
I went with the hedmans. Hedman and Dynomax have a 1/4" flange, Hooker has a 3/8" flange I believe. You'll need to make up a spacer that splits the difference in depth between the header flange and the original manifold where the a/c stud goes. Other than that, you'll be fine with any of these!
-Steve
Old Oct 28, 2003 | 11:48 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: which headers to buy? (Pacin'California)
If you have to pass a visual inspection for emissions, and have to have the A.I.R. system installed, go with the Hedman headers.
Old Oct 28, 2003 | 12:44 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: which headers to buy? (BSeery)
dynomax :thumbs:
To which headers to buy?
