How do I tear this ^%#$*^%$*&% thing out????
Old Oct 29, 2003 | 02:34 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Default How do I tear this ^%#$*^%$*&% thing out????
Hi All,
I'm a rippin' and a tearin' on my '72. I need some help though.
I have this useless vacuum box under the fender on the driver's side.
I stood on my head and STILL can't see WTF is holding it on. No bolts visible at all from above. Looked underneath and can't see much either. One possibility comes to mind. The eggcrate vent on the side of the car. If I remove that MAYBE I'll be able to see what's attaching it. Is that how everyone else gets at this friggin thing??? :mad
Dep
Old Oct 29, 2003 | 02:38 PM
zwede's Avatar
zwede
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (Dep)
It's the vacuum tank for headlights and wiper door. It has a bracket welded to it that bolts to the inner fender. The bolts are accessible through the wheel-well (remove the drivers front wheel for ease of access).
Old Oct 29, 2003 | 02:42 PM
DJ Dep's Avatar
DJ Dep
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (zwede)
EXCELLENT! I owe you a pizza of your choice Zwede!
:thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
Dep
Old Oct 29, 2003 | 04:21 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I hear ya. I had to go through the same thing when we replaced the front cap on my car.
Old Oct 29, 2003 | 04:45 PM
toddalin's Avatar
toddalin
The box is not useless, but is prone to failure, typically cracking which results in a loss of vacuum, sluggest headlights, etc. These can be hard to find. If yours is bad, I have a couple on the shelf.
Old Oct 29, 2003 | 05:25 PM
theandies's Avatar
theandies
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (toddalin)
What this vacuum reservoir does is allow you to actuate the headlights without having to run the engine. It stores vacuum.........if your system is tight. My system is OK, I can actuate my lights once after shutting down the engine but the vacuum only lasts about 10 minutes before it bleeds up. I was going to take it out (Its not necessary unless you want the function mentioned above) and put my MSD box there but I realized how hard:banghead: it is to get out I put my box on the other side.
Old Oct 29, 2003 | 05:40 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (theandies)
I tried to get mine out to do repairs on it. I had the whole thing loose in that little area where it sits but couldn't get it out because of the master cylinder.
Old Oct 29, 2003 | 06:36 PM
DJ Dep's Avatar
DJ Dep
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (Eddie 70)
The box is useless to me because I no longer have the wiper door and headlight stuff hooked up. I need it out to get at the wiring connection from the engine to the firewall. I still wonder if it would fit through the egg crate vent? Is the box made out of plastic? I can smash it to a pulp if it is.
Dep
Old Oct 29, 2003 | 06:44 PM
Wrencher's Avatar
Wrencher
Metal. Probably do more damage to the surrounding 'glass than the tank if you force it. Take off the master cylinder to remove it. Again, an original tank (with the little stamped numbers) is worth $$$, so I'd E-bay it...
Hans
Old Oct 29, 2003 | 07:01 PM
DJ Dep's Avatar
DJ Dep
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (Wrencher)
I'm still gonna try the egg crate vent. I may have "discovered" a new trick to repairing/replaceing that stoopid thing :D
Dep
Old Oct 29, 2003 | 07:20 PM
PRESSURERAT's Avatar
PRESSURERAT
You have to take the fasteners off first.
Old Oct 29, 2003 | 07:33 PM
DJ Dep's Avatar
DJ Dep
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (PRESSURERAT)
The fasteners on what? The egg crate thing looks like it has 2 phillips screws holding it on from the top. I know there will be nuts of some kind holding the vacuum box on. That's what i can't spot right now.
Dep
Old Oct 29, 2003 | 07:42 PM
GDaina's Avatar
GDaina
Don't bust it, whatever you do....that vacuum tank is worth biiiiig bucks
Think it's way too big to take out the egg crate hole.
Master Cyl removal is the only way I know how to get it out. Can't remember if I had to pull the steering column, or if the column was out.
Old Oct 29, 2003 | 07:55 PM
DJ Dep's Avatar
DJ Dep
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (GDaina)
Okedoke. I just put a new master in and haven't done the bleed job on it yet so it's no biggie. Cripes...if I have to pull the steering column I'll get a hacksaw and cut it (the vacuum box) out in pieces!!!!! No way I want to yank out the steering column. At least, not YET. Eventually I plan on installing a T&T column, but that's way down the road.
Dep
[Modified by Dep, 6:57 PM 10/29/2003]
Old Oct 29, 2003 | 08:01 PM
Bullyj's Avatar
Bullyj
Don't cut it up smash it with a big hammer it's much more satisfying. :smash: :smash: :smash: :smash: No just kidding
Old Oct 29, 2003 | 08:53 PM
theandies's Avatar
theandies
Dep
Dep
Along with the two screws at the top, the egg crate is also held on be a nut and stud on the bottom. If you look up behind the rocker panel with a flashlight you'll see it.
Old Oct 29, 2003 | 09:46 PM
DJ Dep's Avatar
DJ Dep
Bullyj: My favorite tool! You should have seen my AC box after my ball peen got done with it!!! :D
theandies: thanks for the tip. I'll probably have to take it off to remove whatever holds the vacuum tank on.
Dep
To How do I tear this ^%#$*^%$*&% thing out????
Old Oct 30, 2003 | 12:56 AM
Chuck Harmon's Avatar
Chuck Harmon
Gentlemen,
I think we have found our Bubba poster child!
:smash:
Chuck
Old Oct 30, 2003 | 02:07 AM
RC73's Avatar
RC73
Default Re: How do I tear this ^%#$*^%$*&% thing out???? (Chuck Harmon)
Bubba in da house. Go Bubba. Go Bubba :jester
Old Oct 30, 2003 | 08:26 AM
Edzred72's Avatar
Edzred72
Pulling the egg crate will give you perfect access to the forward lamp harness and engine harness as it comes out of the firewall. Be carefull of the lower portion of the crate. Crate must be lifted straight up to clear the lower stud after all fasteners are removed. That bottom fiberglass flange of the body can crack easily. Don't force it...
Eddie
