Coolant hose
Old Oct 29, 2003 | 03:10 PM
Larsson's Avatar
Larsson
Default Coolant hose
The previous owner has use a rather bad solution when replacing the hose for the cooling fluid between the radiator and the engine.
If you look closely you will se a small plastic band that holds this standard hose to the radiator so it wont touch the belt. If this band breaks I'll have a mess.
My motor-english is bad, so I wonder if this: http://www.zip-products.com/Corvette...B95AD8961E91AC
is the product i need? (Yes it is a 72)
Is there normally any fluid in this hose when the car has stood for a couple of hours? I suppose that the fluid sinks down to the level in the radiator.
Old Oct 29, 2003 | 05:26 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Default Re: Coolant hose (Larsson)
I believe that is the right hose.
