Raybestos Brake Pads
Old Oct 29, 2003 | 05:57 PM
Tom Johnson's Avatar
Tom Johnson
Default Raybestos Brake Pads
Has anybody used the Raybestos Raymold line brake pads? These are organic brake pads that are sold at Checker Auto.
Old Oct 29, 2003 | 07:05 PM
Larry B.'s Avatar
Larry B.
Default Re: Raybestos Brake Pads (Tom Johnson)
I haven't tried that particular brand but typically organic pads are quieter and more suited for everyday driving.
Old Oct 29, 2003 | 07:16 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
better to be safe and use performance friction carbon metallic.
organic squeel like crazy and don't stop so good.
Old Oct 29, 2003 | 07:38 PM
flood's Avatar
flood
Default Re: Raybestos Brake Pads (turtlevette)
I have put on two sets of orgainic and both have squeeled. Next time im trying some semi metalic or better.
I did resurface the rotors and it helped but I still get some squeel.
Old Oct 29, 2003 | 07:50 PM
Drew M's Avatar
Drew M
Maybe thats why my brakes squeel like all H. E. double hockey sticks!!
Old Oct 29, 2003 | 07:56 PM
Larry B.'s Avatar
Larry B.
I have found the opposite. Quiet and less pedal effort when cold.
Old Oct 29, 2003 | 09:11 PM
MN-Brent's Avatar
MN-Brent
Default Re: Raybestos Brake Pads (bluevetteman)
I use Raybestos PG Plus in my other cars like 98 ZR2 Blazer and wifes Mazda 626 and they work real good, nice and quiet and stop great. I also do many friends brakes for beer and they never complain about noise.
Always turn the rotors though.
Brent...
Old Oct 29, 2003 | 11:40 PM
zwede's Avatar
zwede
Default Re: Raybestos Brake Pads (MN-Brent)
I'm using raybestos brutestops on my 71. Some slight dusting (really not much, though) but NO NOISE. After the squeling perf friction pads that was a relief.
Old Oct 30, 2003 | 12:08 AM
Ironcross's Avatar
Ironcross
Raymold is the cheap line of that product. The premium line would be better, use the "PG`s". Several lines also offer the molded semi metallic with noise silencers on the back of the pad. This would be the best choice, but only available in there premium lines. These do not have any rivits holding the pad to the plate. Wagner is another good brand, but not the cheap Wagners. ALWAYS have the rotors machined with every brake job to make sure they are true and it will help prevent a pulsing pedal. Another thing, it is not always necessary to buy new rotors, thats why rotors are machined. But be careful, most of the cut rate horses out there are merely selling price with a so called lifetime warrantee, not quality. Stick to brand names. :thumbs:
Old Oct 30, 2003 | 12:12 AM
jamiejamison's Avatar
jamiejamison
I'm using Raybestos Brutestop on my 1980 and finally got a quite pad. Also 40 % less braking force needed. Holds me at the starting line when cranking
2500 rpm. JamieJ
To Raybestos Brake Pads
