Hoping someone can diagnose this problem...loose steering on my 73 even after TOTAL suspension rebuild. (springs, struts, all bushings, tierods&ends, shocks etc. all VBP products, from kit.) When I say "loose steering" I mean that the wheel seems too easy to turn especially at speed. There is no slack, any small turn of the wheel turns the car, but turning the wheel seems not stiff enough. Doesnt give me enough feed back. The power steering valve was replaced a couple of years ago. Best way I can discribe this is too much power steering. Is this just how they feel or is there someway to tighten this up? Ideas?
When the front end was reassembled, were the outer tierods put into the hole in front or back on the spindle?? There's only about a couple inches of difference there, so they will both work, but one will feel "tighter" than the other.
If it's in front, the ratio will be like 21:1 and if in the rear will be a much nicer 16:1.
A couple of thoughts: Did you replace the PS control valve? I believe the replacements and rebuilt valves have a lighter spring in them- 40# vs the original 55# springs. This would change the road feel you're talking about,what about the steering gear did you replace or rebuilt it? Usaully the hole in the steering knuckle is plugged at the factory on original equipment PS cars.
Gary
Check the Corvette FAQ site, there is a great writeup about the spring used in the power steering control valve. The new/rebuilt ones come with the higher spring rating, and as someone previously posted, you probably want the lighter spring. The article explains the different springs well. http://www.corvettefaq.com/
You mentoned a complete front end rebuild, but didn't mention replacing the idler arm, so I would first suggest checking that if you didn't. (I'm guessing you did since your steering isn't loose.) The standard idler arm that comes on GM cars isn't able to be greased, the heavy duty one (Moog & TRW have them) has a grease fitting, is really beefier and lasts much longer.
Experience has shown me the two biggest culprits in loose steering and most often overlooked are the idler arm and the rag joint.
I too rebuilt my front suspension using all polyurethane bushings. I used the VB kit and also put in a new power steering cylinder, control valve and lines. The steering was excellent, but in no way overboosted. The wife hated driving it. (Not really a bad thing!) Anyway a while later I noticed the steering box leaking and since I didn't have the time, sent it off to Van Steel. All I can say is wow!!! It came back looking better then new and all of a sudden it seemed I really did have power steering, but like you I've noticed it seems a bit overboosted. Wish I'd done it while I was autocrossing!
Thanks for the info...to answer some questions and help clarify...I did replace the idler arm with the vbp "heavy duty" one. I am not sure which hole on the spindles was used...what would be like stock?...also I did nothing to the steering box or rag joint...it was my understanding that any problem with either of these would result in play where you turn the steering wheel and nothing happens...this is not the case...keep the ideas coming!
BTW The ideal steering feel to me is one like on my Dad's 86 where it feels like a big go cart...but you can still park without Popeye like forarms.
